Serpentine belt diagram
WANDAKAY EVANS
  • 2012 CHEVROLET IMPALA
  • 3.6L
  • V6
  • 67,000 MILES
I need diagram for serpentine belt replacement
Saturday, March 18th, 2017 AT 10:22 AM
HMAC300
  • 48,601 POSTS
That should be on the panel above radiator most cars have that unless someone stripped it off see pic for diagram. Tensioner should be replaced as well if replacing belt. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Saturday, March 18th, 2017 AT 2:07 PM
RODNEY FRANCOIS
Do I torque the tensioner towards the front or back of the car to loosen the serpentine belt?
Wednesday, June 21st, 2017 AT 4:26 PM
HMAC300
  • 48,601 POSTS
Which ever way is away from the belt over the pulley
Wednesday, June 21st, 2017 AT 5:55 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 2007 CHEVROLET IMPALA
  • 105,000 MILES
I had the rack and pinion replaced and the power steering pump, belt tension, serpentine belt, power steering line replaced my car is making a whining noise can you give me the belt diagrams so I can replace it?
Thursday, June 18th, 2020 AT 1:34 PM (Merged)
  • 52,797 POSTS
Here is a guide to help you change the serpentine belt out with the routing diagrams in the diagrams for your car below.
https://www.2carpros.com/articles/replace-serpentine-belt
WRENCH35
  • 2006 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 76,000 MILES
What is the belt serpentine belt routing for an 06 impala with a 3.5 liter engine?
Thursday, June 18th, 2020 AT 2:12 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
3.5L Engine - 5.3 Liter is in the diagrams below
https://www.2carpros.com/forum/automotive_pictures/261618_GraphicCAS5A2TH_1.jpg
Install by starting at the generator, route belt around all pulleys except for tensioner. Rotate belt tensioner clockwise in order to release the spring tension. Install drive belt around the tensioner.
This guide can help as well.
Cheers
MDYKES3948
I need to change the belt on my car becasue I can see cracks. Can I get a diagram to put the belt back on? 3.5 engine Thanks! Love this site.
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide that will give you an idea on what you are in for when changing the belt:
Here is the diagram (below).
Cheers
JIS001
  • 3,408 POSTS
I was looking at both 3.5L and 3.9L and looks to me like they are the same? Here is diagram for a 3.5L.
And this one is 3.9L.
https://www.2carpros.com/forum/automotive_pictures/337695_39L_1.jpg
Hope this helps you?
BEASLE1
  • 6 CYL
  • FWD
  • 60,000 MILES
I have a 2006 chevy impala and I need a serpentine belt diagram
SATURNTECH9
  • 30,870 POSTS
There you go.
DOCFIXIT
  • 18,828 POSTS
Hope this helps.
TSHORT82392
  • 5.3L
  • V8
  • FWD
  • 73,000 MILES
I need to replace my alternator, but I want to replace my serpentine belt also, I just need the diagram for it, as I cannot find it anywhere.
HMAC300
  • 48,601 POSTS
If you go to repair and service then diagrams it is right there. However, if you are replacing belt replace tension-er as well as it is worn out too. See picture.
2CP-ARCHIVES
  • 4,542 POSTS
  • 122,900 MILES
I need to find the diagram to replace my serpentine belt
Friday, June 19th, 2020 AT 10:22 AM (Merged)
HMAC300
  • 48,601 POSTS
It's on the site here when you first sign in look to the left under belt diagrams
DARKMAN13
  • 5.3L
  • V8
  • 133,265 MILES
My serpentine belt broke and I was wondering where is the tensioned located at and what tool I need to loosen it up, is there a video that would show me.
  • 108,133 POSTS
This guide should help walk you through the steps.
It is a different model GM vehicle, but should help.
SCOTTX3
  • V8
  • FWD
  • 100 MILES
I have the SS model with a 5.3 liter engine. I am in need of a serpentine belt diagram since Chevrolet failed to put on on this vehicle.
What tool and size of the socket I need to perform this duty?
Love this site!
Friday, June 19th, 2020 AT 10:23 AM (Merged)
