Dash board lights?
2008 CHEVROLET IMPALA
130,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
RIVIERACOLEMAN
  • 17 POSTS
When I turn on the ignition the radio and dash board lights some times come on and some times they do not. The key is stiff and sometimes it will not start
Jun 13, 2017 at 4:45 AM
STEVE W.
  • CAR REPAIR CONTRIBUTOR
  • 15,157 POSTS
Sounds like a failing ignition switch or cylinder. These were subject to a recall for the ignition switch so you might want to make sure that was completed. If not here are the instructions in the diagrams below to show you how to replace the ignition switch which should fix the problem. Check out the diagrams (Below). Please let us know what happens.
Jun 13, 2017 at 8:16 PM
LADAWN
  • 0 POST
Getting a new ignition switch from the dealer cost me $162.00 fixed it.
Aug 23, 2019 at 3:56 PM
FRIDAY5PUD
I am driving a rental car and I had no dash light come on this morning. There is no indication in the book as to what this means. Is there somewhere I can go on-line that would give me a list of what these warnings are and what to do about them? Thanks!
Aug 23, 2019 at 3:59 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
It sounds like a fuse is out here is a guide to help you test them with the fuse locations below.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
FLEX19149
Hi i have 2007 impala my dashboard lights comes and off but the heat and Ac still work but no dashboard lights didnt check fuses yet because they come on then go out somtimes it stays off so i was thinking cant fuses
Aug 23, 2019 at 4:00 PM (Merged)
HMAC300
  • 48,601 POSTS
have it scanned for codes and check connection to cluster and body control module I tmay be a body control module however. or a lan/data line broken
GBROWNEYEZ41
Interior problem
2004 Chevy Impala 6 cyl Automatic
How do you change the dash lights on a 2004 Chevy Impala? The light at the gas gauge has gone out.
WRENCHTECH
  • 20,761 POSTS
The dash cluster has to be removed to access the bulb sockets on the back.
INSTRUMENT PANEL CLUSTER (IPC) REPLACEMENT
REMOVAL PROCEDURE
IMPORTANT: The ignition switch must be in the OFF position when removing the instrument cluster.
1. Remove the instrument panel (I/P) cluster trim plate.
2. Remove the instrument cluster screws.
3. Pull the instrument cluster towards you and disconnect the electrical connector.
4. Remove the instrument cluster from the I/P.
INSTALLATION PROCEDURE
1. Connect the electrical connector to the instrument cluster.
2. Install the instrument cluster to the I/P.
NOTE: Refer to Fastener Notice in Service Precautions.
3. Install the instrument cluster screws.
Tighten
Tighten the instrument cluster screws to 2 N.m (18 lb in) .
4. Install the I/P cluster trim plate.
5. If a new instrument cluster was installed, program the cluster. Refer to Service Programming System (SPS) in Vehicle Control Systems.
BAMAGIRRL722
My dash lights went about a week ago and now the instrument panel does not stay on. The lights on the radio also go out. I have checked all the fuses and they are good. What could it be?
RENAUDTN
  • 636 POSTS
I have the same problem. After research online, it seems that it could be either a defective BCM or ignition.
From what I read on different websites, this is a common problem with impalas.
You can't replaced the BCM by yourself because I think it needs to be calibrated at the dealer. However, you probably can buy one online and take it to your dealer. It may save you a little bit of money.
BASTOOPS
i would like to appologize if this turns into a long post. but it started about a year ago and has steadily gotten worse. so last summer i noticed this clicking noise coming from the dash. it would start when you unlock the doors or start the vehicle. it clicks for a few minutes then stops. while its clicking you can turn the vent control dial and the clicking will stop while the vents change from floor to front and then it starts again. well a few months ago i was driving and noticed a burning smell coming from the dash. it went through this fit for a day or two where all the inside lights would flicker like a strobe light then all the sudden it just stoped, almost like a fuse burnt out or somthing. shortly after that most of the dome lights and dash board lights quit working along with the driver seat, the seat will go up or down, but it wont go forward or back, i dont know if its the motor that controls the seat or if its also related to the other problems i am having. it seems like all the lights that quit working are on the same circuit. i dont know if its a fuse or somthing. i'm sure its all linked together somhow. any help or information is appriciated. thanks.
Aug 23, 2019 at 4:01 PM (Merged)
MERLIN2021
  • 17,250 POSTS
I am going to tell you what you may not want to hear(read), This will require a trip to the dealer to have the B and U codes read, On these new models, this is the first step, and believe it or not, will save time and money by not guessing and throwing money at it blindly.
RHALL77
  • 3,361 POSTS
I agree, most likely the cause is a bad body control module. this is very common in the impalas
MERLIN2021
  • 17,250 POSTS
Always nice to have backup from Mr. Goodwrench!
TIFFANY COUBAL
No dash lights at night instrumental panel is dark when car is running at night. I the fuses and the is still no lights at night on the dash or the radio.. What could be wrong with the lights........the light come on during the day but there are no lights at night
SEANGRANT00
  • EXPERT
  • 334 POSTS
Have you checked the dimmer?
TIFFANY COUBAL
Yes I've tried the dimmer and the lights still are not readable. they work only during the day light.....a so as it gets dark outside the sensor kicks of and the dash lights are dark.
SEANGRANT00
  • EXPERT
  • 334 POSTS
It sounds like the dimmer. During normal light conditions or day time, the dimmer is not used and a default max light setting is set. After it becomes dark, the ambient light sensors turns on the dimmer and it goes from there. Check power going to the dimmer and let me know what you find.
Sean
BOBSHOP
I asked the question about "dash lights in a chevy impala'03 LS", your repy was to check fuses and rhetsostat, I did all this and they still dont want to work. any more suggestions???
Aug 23, 2019 at 4:02 PM (Merged)
JDL
  • 16,098 POSTS
So the dimmer for your interior lites, has no effect? Any applicable fuse, did you check for voltage on the fuse circuit, using a voltage tester? Even if the fuse is good, if no voltage, the circuit is dead.
JDL
  • 16,098 POSTS
Here are a couple fuses to check. You see the park lamp relay, the squiggle line on the right side, that is ground for the relay. Grounded by the bcm. The bcm has to receive a sense signal from the headlamp switch, to ground the relay.
RENAUDTN
  • 636 POSTS
This post was initially to ask advice about my dashboard lights (they wouldn't come on at night).
After some troubleshooting I finally found out what was wrong: the headlight switch. One of the pin on the switch had shorted out (the one where the grey wire connects for those who may want to know).
Here is the troubleshooting procedure:
Remove the headlight switch (you have to remove, or at least losen up, the instrument panel bezel...it's easy, we're talking about 6 or 7 screws).
Once it's unplug, put a jumper across the brown/white wire and the grey wire (there are two grey wires, the one you're interested in is the one that is farthest away from the brown/white wire; NOT the one right by the brown/white wire).
When you put the jumper accross the wires, the dashboard lights should come on (make sure you do this test when it's dark around otherwise you won't see it).
If the lights do come on, replace the headlight switch ($120). If they still don't come on, you may have a module problem.
NATETRADE_99
I have the same problem. Did you find a fix?
NATETRADE_99
I fixed it. Thanks anyway!
RSPAWPAW
I have a 2003 chevy impala, when i make a left turn, the ABS light and the trak light comes on. The message center tells me to service the traction system. is this transmission problems? i have completely redone the front end: new hubs, inner and outer tie rods, cv joints.
FIXITMR
  • 9,990 POSTS
1 of th front wheel sensors is probably cutting out. could be a connection problem. inspect sensors and wiring/plug
JUDY & HOWARD HUEY
The dash lights go off for extended periods of time.
CONSAKA
  • 31 POSTS
This is caused by a poor electrical connection.
To fix it start with the dimmer switch that controls how bright the dash lights are. Make sure it is working properly and has no loose connections. If that turns out fine then you may have to take the dash apart to trace it out. before doing that though check the fuse connections and make sure those are good. Pull the fuse and put it back and see if that helps.
Of course to trace it out properly it needs to be not working at the time. You will need an electrical meter to test which wires are hot and which are not..
It is highly likely that once you start working on it it will work fine for a while.
AMC2506
The abs and traction control lights are on how or do i have to take it to dealer to find the problem and fix it?
WRENCHTECH
  • 20,761 POSTS
Not necessarily the dealer but you will have to find a shop that has a professional scan tool with ABS software to read the code stored when the light came on.
AWADE1982
I just replaced my ignition switch and gotten my key coated, after my ignition switch went out. Now, when I try to crank my car nothing happens. I thought that i need a new relay switch, so I replaced that too. Whats funny is that when i take the relay switch out and touch the metal with a wire the car will try to crank. When I try it with the key, you can hear the computer system and dash board lights turn on but it still want crank. Help me please!
THUNTER137
  • 5 POSTS
2003 Impala 3.8L, LS, 45,000 miles
I turn the key and it won't start or click. Everything lights up. It has happens at least once a month for the last 6 months. Doesn't matter if the car is cold or hot. I will have to keep turning the key about 50 times to get it to start. After that it is fine. I can then turn it off and on. I took it to the chevy dealership and they said they could not find a problem. They said I will have to wait it out until it won't work at all instead of putting a lot of money into a problem no one is sure about
SJB133
[quote="thunter137"]2003 Impala 3.8L, LS, 45,000 miles
my 2002 impala done this, dealer told me the same thing at first. they finally(2 yrs later) told me what it was and if my security light was on it would throw a code. i took it to a shop and sure enough it did. it was the passlock cylinder. had to replace the whole ignition switch and have it reprogrammed. there needs to be a recall on these, badly.
BOBSHOP
my car has no dash lights, what could the fix be?
Aug 23, 2019 at 4:21 PM (Merged)
  • 31,937 POSTS
Check fuse for side lights, check that the light rheostat is not turned down if fitted, check this first.
mark (mhpautos)
BABOY26
Electrical problem
2002 Chevy Impala 6 cyl Automatic 149,00 miles
hi i have a 2002 impala..and the dashboard and taillight turn off at night...? i check the fuses and there just fine..
BMRFIXIT
  • 19,053 POSTS
Use a test light and or volt meter
turn lights on and check each and every fuse
90 % its a fuse
if 100% fuses OK check and suspect light and dimmer switch
Aug 23, 2019 at 4:22 PM (Merged)
DICKSIMPALA
On startup, the dash lights come on, then immediately dim. The dimmer control does not work, light on the instrument panel stay dim.
Checked what fuses I could find, but not sure if all were checked.
thank you
RHALL77
  • 3,361 POSTS
are they dim at night also. can you adjust them at night
DICKSIMPALA
In the night mode; the lights for the instrument panel are completely out. The lights for the gear selector and radio go to very dim. The dimmer switch has no effect.
In day mode, the lights are normal.
Wonder if it is the night time sensor on the dash....
