2CarPros - Car Questions & Answers
2001 Chevrolet Impala Repair Question
Topics covered: Engine, Fuel filter, Engine performance.
Asked on October 25, 2008
Chevy engine miss on idle
Engine Performance problem
2001 Chevy Impala 6 cyl Front Wheel Drive Automatic 114000 miles
I have an ongoing mild engine miss when idling. I have already replace the fuel filter, spark plugs, wires and added a gas additive. I have also checked for arcing at night on the wires, but haven't been able to find any problems there. The car worked fine until I recently had the transmission overhauled. Could there be something that they may have done to create this problem. The service engine light has not come on or any other codes. Is there something else that may be causing this miss in the engine. Please let me know what you think.
Thanks
Brian
Avatar Asked by SHULL1959
Answer
Replied on October 26, 2008
Hi Brian:
Since there are no codes, and the problem started after the trans repairs, I would look for a vacuum problem. They may have left a hose off or damaged one without realizing.
Let me knowif this helps, or if you have any other questions.
Tiny Answered by Jacobandnickolas (expert)
57,475 answers provided
Thanks Joe for replying.
I have had a look to see if any vacuum lines were off or pinched shortly after this started and didn't really see anything. I will go overthem again, I might have missed something and let you know.
Thanks
Brian
Tiny Response from SHULL1959
1 question asked
Hi Joe;
I just went over the car again and couldn't see any lines that were lose, kinked or off. Look like we are back to square one. Someone else mentioned putting Berryman's B-12 cleaner in it for the injectors. Their thought is possibly fuel. I have already put in injector cleaner and changed the fuel filter. Do you think that this would help or a waste of money?
1 question asked
