power steering not working?
2010 CHEVROLET IMPALA
68,000 MILES
MNLGRANILLO448
Hello, my 2010 Impala's steering has gotten firm recently. When stationary and turning the wheel, it will squeak for a second or two when turning left or right. I have checked the power steering fluid level and it is at the correct level with no visible leaks. The high pitch squeal does not happen when driving, but only when stationary and comes from under the hood. Is it possible that I may need to change the belt & the tensioner?
Oct 14, 2013 at 8:21 AM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
This happens when the system power steering pump goes bad here is a guide top help walk you through the steps with instructions in the diagram below show you how on your car.
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
and
https://www.2carpros.com/articles/remove-reinstall-power-steering-pulley
Oct 14, 2013 at 9:14 AM
BROWNN
Nice work I had this issue had to ge a new pump cost me $132.00 all fixed
Dec 19, 2019 at 4:39 PM
DIANNAW
All of a sudden it was making a shh noise and slower to get into gear. Seems to be better once it gets up to thirty mph even the shh seems to quite down. But then this morning when I went to move it the steering wheel was very hard to turn, but after running for a couple minutes it seems better. is this an expensive fix? Please Help!Thank you!
Dec 19, 2019 at 4:40 PM (Merged)
HMAC300
  • 48,601 POSTS
have a mechanic check for a either a broken power steering line or low fluid, bad pump or steering rack.
DIANNAW
So I added fluid the steering seems to be fixed. The noise is a lot less, but still I can hear. Was told it could take a little bit to get gunk worked out or it could be the pump? Thank you!
HMAC300
  • 48,601 POSTS
well if it was low on fluid then it leaked out someplace and normally that can be a loose connection on a line or leaking out the rack and pinion. look if you can to see if you see any oil around any of the lines top and bottom. If the pump does not make a lot of noise and you can put up with it then just drive it. check pump fluid in a couple of days.
KSSPAVIA
My power steering pump was going out( what i was told) , eventually became extremely hard to steer, yet still ran well amd all. Low on cash i still drove it for quiet some time(4 months or so ) my bicepts became very cut , and other than squeking/whiney noise and tough steering, ran just fine. Until, a mechanic friend of mine attempted to fix the problem.replacing the pump and belt with new/ used part. Well, while driving home from car shop my vehicle began to overheat(EXTREMELY) i had to pull over to let cool. Checked under the hood and discovered belt was now shredded. Car wouldnt start again that day- had it pulled/towed home. Days later bought a brand new belt and installed it. And charged car battery. Attempted to drive to work in which car only made it a few blocks before battery dying/ overheating AGAIN.... vehicle hasnt even started up again since. HELP! What to do ???
HMAC300
  • 48,601 POSTS
check pulley alignment with a straight edge the new belt is probably shredded again due to alignment problem with newly installed part.When changing belt also replace belt tensioner
LACEUPALLDAY
The cruise control buttons,volume up and down buttons, and horn do not work at all on my 2010 chevy impala. it was like this when we got it from the dealership kist never had the time to take it back to get it checked. any helpful ideas to get this fixed without taking it in to a shop???? I know the fuses are not blown and i have a feeling it has something to do with the wiring under the dash.
Dec 19, 2019 at 4:41 PM (Merged)
CARADIODOC
  • 34,309 POSTS
You didn't provide any details about why you suspect a wiring problem or why it was at the dealership. The most likely suspect is a broken clock spring under the steering wheel, but that assumes there isn't some other recent repair or problem that could be related. The clock spring is a wound-up ribbon cable in a plastic housing. They often break on the ends, and they can be damaged if the steering wheel is turned repeatedly while something is disconnected for other repairs.
MS2013
I just bought this car after years of driving old and hand me downs. Sometimes when I turn, the steering wheel makes a sound. The sound is like my seatbelt rubbing on something. Its a subtle noise. The russ darrow kia in fond du lac keep telling me its fixed.
Dec 19, 2019 at 4:42 PM (Merged)
CARADIODOC
  • 34,309 POSTS
"Subtle" noises are common now because cars are becoming so quiet. We can hear things that we couldn't before, especially stupid little wind noises. Some belt noise is normal, and GM has had some trouble with noisy power steering pumps.
I would have another mechanic listen to it but don't cloud his judgement by mentioning that anyone else has looked at it until after he gives you his opinion. If he says it sounds normal it probably is.
P.S. I'm in Wausau.
TONYWINDOM
  • 7 POSTS
When my 2003 impala turns, my power steering squeaks. Why is that. I want to put in fluid but i cant find where to put it at. The engine is 3.8l
back of motor down low on passenger side. not easy to get to
TONYWINDOM
  • 7 POSTS
So is the squeaking cause by low power steering fluid level
winning would be, squeeling may be from the belt. the tensioner may be weak.
TONYWINDOM
  • 7 POSTS
Would that cause my check light to come on
we need the code. have it pulled and get back to us.
BOONDOX
We've had this LS since 03 and it started making some strange noise recently. It's a low whine that's changes with moving the steering wheel. I thought was the PS pump, but I can't find any leaks at all. Looking under the car there is a huge amount of what looks like the cheapest, nastiest grease I've ever seen. This has a shadetree mechanic friend thinking it's something in the drive axels.
Dec 19, 2019 at 4:43 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
Where is the grease, around the cv boots?
BOONDOX
It's all over the CV boots, where it's heavier, but travels all the way up. This stuff doesn't even feel like grease and it looks like it's got small gravel in it.
SERVICE WRITER
  • 9,123 POSTS
My guess is that if you look clese enough you'll find a boot that is split and spinning the grease out. Just debris kicking up while driving is probably where the grit is coming from.
MFYUMYUM
Put a new power steering pump on when you first crank car steering is easy after that gets very hard to turn wheel
JDL
  • 16,098 POSTS
Maybe the problem is the rack and pinion and not the power steering pump? Usually when you replace the power steering pump, the info says to flush the system, get the old fluid out of it. In the past I have taken return line loose from the pump, aim the return line into container, rotate the pump pulley by hand to circulate the old fluid out. When the fluid runs clear, the old fluid is gone. I guess the new fluid is clear and not colored? That will also show you that there is circulation. If no circulation, maybe power steering hoses have a problem? I haven't looked up your power steering pump operation. If the info I posted isn't applicable, I'll find more info.
JDL
  • 16,098 POSTS
Just to add, you have to keep adding fluid when you flush it. The hi pressure hose is usually a threaded fitting, the return line is usually low pressure and uses a hose clamp.
MFYUMYUM
When you first crank car steering is easy after a couple right and left turns gets hard to turn
RJWYLIE
I cannot find any place to check the power steering fluid level. I read an article about some GM vehicles having electric steering of some sort. Is that on this car or am I just overlooking the check tube.
RHALL77
  • 3,361 POSTS
what engine do you have. what liter
MFYUMYUM
Driving down road steers fine sitting in park gets hard to turn
RJWYLIE
The engine is a 3.8 6 cyl.
  • 54,350 POSTS
There is a speed sensor located in the steering column or the rear of the pump that has gone bad, this sensor tells the steering system how much pressure to release at a particular speed. Please check it out and get back to us so it can help others
RHALL77
  • 3,361 POSTS
its on the passenger side by the fire wall down deep into the engine bay. Right side of the engine towards the front of the engine
JSLIGH34
  • 12 POSTS
Very hard to turn steering wheel when not stepping on gas.Turns normal when stepping on gas, whether in park or driving. When turning wheel, it makes a "shhh" noise, or like an air sound. That's the best I can describe it. Also, sound comes from each of the front tire areas, rather then the pump. Dealership changed power steering pump and it made no difference. One place says bad pump and one place says bad rack and pinion (but there's no loose turning/slipping) PLEASE HELP ME.
SATURNTECH9
  • 30,869 POSTS
It does sounds like it could be the rack but I have seen where the steering wheel angle sensor goes out and causes the same thing. To test the pump you need a flow test
Here is the location, its not to easy to replace but it fixed the last car we had in the shop.
Check out the diagrams (Below)
Please let us know what you find.
Cheers
JSLIGH34
  • 12 POSTS
Can the pressure and flow test be performed by myself, or will I have to take it to a mechanic?
Also, how long does it normally take to have the rack changed?
I appreciate your response(s)
SATURNTECH9
  • 30,869 POSTS
If the dealership told you that replacing the pump would fix your steering problem then i would take it back there and make them fix it for no additional charge. Changing a rack and pinon takes different amounts of time depending on your rack set up.
JSLIGH34
  • 12 POSTS
Ok. So my best bet would be to take it and have the pressure and flow test done. Then, if all is well in that aspect, to have them check out the rack and pinion?
Also, could there be a lose hose or something that's possibly disconnected from the rack? There's no leak or anything.
SATURNTECH9
  • 30,869 POSTS
The flow pressure test will see if the pump is good and if its good and the sensor is good you have a bad rack
JSLIGH34
  • 12 POSTS
Ok I will take this all into consideration and see what happens. Thanks a lot for everything.
SATURNTECH9
  • 30,869 POSTS
Your welcome thats what were here for.
