I need to locate the turn signal flasher on my 2005 Chevy Impala. I have looked under the dash and cannot seem to find it.
Mar 10, 2009 at 3:14 PM
LSAUTO
CAR REPAIR CONTRIBUTOR
It is a black box with a 2 or 3 wire plug-in. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to enlarge)
Mar 10, 2009 at 6:55 PM
MICHELLE STEPHENS
MEMBER
1 POST
Where is the flasher relay located?
Nov 2, 2020 at 3:14 PM
(Merged)
HMAC300
The flasher is interrogated into the hazard switch and some have a separate flasher than the Hazard switch. Located in the dash behind instrument panel cover above steering column. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
(Merged)
WATLEYSTEVE
MEMBER
1 POST
Inside turn signal stays on,does not flash.How do I fix it?
Nov 2, 2020 at 3:15 PM
(Merged)
RHALL77
they are either part of the hazard switch or controller by the switch.
(Merged)
TWELVEPAWZ
MEMBER
How do I access the Signal Flasher Relay? (Part of Hazard Switch?)
(Merged)
You have to remove the hazard switch and replace it-its built-in.
(Merged)
BLUELIGHTNIN6
take a flat head screw drive and pry the hazard button off. This will break the old switch but it will expose the part so you can get it out. Take the same Medium size flat head and slide it next to the switch at the 4 o'clock position, take a needle nose and grab the switch in the middle. By pulling on the switch and wedging the screw driver between the dash and the switch you will be able to release one side of the switch from the dash. Now without letting go of the switch with the needle nose, take the screw driver and wedge it in at the 11 o'clock position. This will release the other side of the switch. Give it a pull and the whole thing will come out of the dash. Disconnect the wires via the plug being careful not to let the wires pull back into the dash and plug in new switch. Then simply slide switch in the opening and it will click into place
(Merged)
KINGGIRL6
MEMBER
1 POST
I have a 2004 Impala my flashers do not shut off. I have changed the relay switch and pulled out the fuse and they're still on. What do i do? Help!
(Merged)
I am pretty confident that you have a wiring issue. The only way they can stay on is if they are getting power from a different source then the circuit the fuse is on.
If you can turn the flashers on and then pull the fuse, you can then test for power through the circuit until you find where you have it. Clearly you should not have any power when the fuse is pulled so when you find power then you just passed the short.
Lastly I just want to make sure you pulled the fuse for the hazard switch and not the one for the turn signals. They are different.
(Merged)
TWELVEPAWZ
MEMBER
Both have stopped working. Fuse? Where is it located? Is there a "flasher module" ? Where is it located? Do you have any other "tips?"
(Merged)
BLUELIGHTNIN6
check fuse labeled turn signal (15 amp) in the left instrument panel fuse block. most likely it is the relay though, it is actually part of the hazard switch, left center of instrument panel.
(Merged)
CPT87GN
MEMBER
Electrical problem 6 cyl Front Wheel Drive Automatic 100119 miles
weres the flasher located on a 2001 impala 3.4
sometimes when i use the blinker it doesn't work then i push the hazard lights and the blinker works again ?
(Merged)
The turn signal flasher is integrated into the hazard flasher and is located under the dash on the passengers side or in the hazard switch itself. Here is a wiring diagram and location (below) so you can get the problem fixed and some location and how to diagrams.
there is a buzzing sound from turn/haz flasher when t/s is turned on. Replaced flasher, still does it. Replaced t/s switch, still does it. Hazard lights ok. just a buzzing from the flasher when t/s are used in either direction. It does not occur all the time but when it does there is just a buzzing sound no lights or indicator lights.
Nov 2, 2020 at 3:16 PM
(Merged)
PETE#1
MEMBER
1 POST
I am having the same problem 01 chev impala.New multi function switch and flasher changed nothing.Next step ignition switch?
(Merged)
Check and test the turn and hazard switch-turn signal circuit goes thru there before gets back there/front
(Merged)
MIKE1955
MEMBER
1 POST
Cannot locate directional flasher to change it..... checked both fuse panels and under the hood.
Thank you
(Merged)
RHALL77
i think it may be part of the hazard switch. what are they doing. are all the bulbs ok?
(Merged)
CHEVYIMP
MEMBER
I have a 2006 Chevy Impala LTZ that I put LEDs in, it fast blinks and clicks when using the left and right turn signal, but blinks and clicks normal for the hazards. I have not been able to locate the flasher relay. Please Help!
Dec 27, 2024 at 4:10 PM
You must install the LED that have the resistor built in, the flasher part of the lighting is handled by the BCM there is no separate flasher unit.
Dec 28, 2024 at 10:43 AM
