car has no go - low engine power output?
2001 CHEVROLET IMPALA
6 CYL
JIMT
ok, 2001 impala ,,,just bogs down when u try to accelerate takes 2 to 3 minutes to get to 40mph hooked up a diagnostic machine at a parts store. indicated bad erg valve and secondary fan. changed the valve and the fan along with a new fuel pump. again its more like to much fuel as apposed to not enough. a 40 mile trip back and forth took a half tank of fuel. also they took the car to WalMart and had a battery installed, the idjits there busted a vaccum line; but i found that and repaired it.....where do i go from here i'm pulling my hair out........!
Dec 5, 2010 at 7:56 PM
LEGITIMATE007
  • CAR REPAIR CONTRIBUTOR
  • 5,121 POSTS
have the throttle position sensor looked at, it may be no good, if your not getting any codes, and the transmission is not throwing codes, it almost sounds like the vehicle isnt going into closed loop, which indicates bad o2 sensor(s) or engine coolant temp sensor This guide can help us find the problem.
https://www.2carpros.com/articles/engine-has-low-power-output
Dec 5, 2010 at 8:03 PM
JIMT
would that cause the car to actually bog down like its flooding out?
Dec 5, 2010 at 8:14 PM
LEGITIMATE007
  • 5,121 POSTS
yes that it would do it.
Dec 5, 2010 at 8:53 PM
DAWN6133
2001 Chevy Impala Automatic
My Impala just started,putting,stalling,it hesitates and has low power when you push the gas,but then power comes back,when you stop it putts,and when you stop and get out of the car it stinks,a bad odor,I dont see any leaks and it just started this last night,please help?
Sep 17, 2020 at 11:49 AM (Merged)
ERNEST CLARK
  • 1,730 POSTS
First, is your "Check Engine" light illuminated? If so, then that is the first thing you need to check. You can take your vehicle to AutoZone, or any other major parts store and ask them to hook your computer to their scanner. It's free. Once you get the trouble codes, ask them for the definitions. That will point you in the right direction.
From the symptoms you describe, it sounds as if you have an exhaust restriction. Probably the catalytic converter.
To be sure, I'd need to know exactly what your "Bad odor" is. If it smells like a rotten egg, or dead rat, then your catalytic converter has gotten clogged up.
But replacing it won't solve your problem. You need to find out why you converter got clogged up and fix it, or your new one will get clogged up as well.
Most of the time, your engine is misfiring and dumping raw fuel into the exhaust. This melts down the inside of your converter and clogs it up. You need to find out why your engine is misfiring.
LINDS1977
Thanks for the help, first off. So, recently my 2001 chevy Impala seems to be missing out. It has no pick up. I recently had an oil change, also bought fuel injector cleaner and the expensive gas. Its just not shifting into next gear easily at at. I dont know if its about to explode (the engine or transmisson). If u get up to 70 the check engine light starts blinking. I gotta take it in but any ideas what it sounds like? much appreicated and good karma to you and yours.
SERVICE WRITER
  • 9,123 POSTS
Too much fuel is entering the combustion chambers and not being burned efficiently. The raw fuel is getting into the converter and damaging it.
DON'T PUT THIS OFF!!!!
You may need a converter if it is too late and whatever the source of the problem is.
The OEM converter warranties are 8years/80,000 miles through the dealer.
JAMIE78,
When I accelerate the car weather in park or in Drive I get a squealing noise while in drive and accelerating I get a loss in power I replace the power steering pump redid the water pump had alternator tested put a new tensioner arm on it new serpentine belt
Sep 17, 2020 at 11:50 AM (Merged)
HMAC300
  • 48,601 POSTS
disconnect belt and start car if no squeal it may be an alternator bearing or idler bearing causing it. if squeal is still present then have engine checked. may be a dry seal or something similar.
JROB77US
I have a 01 impala with a 3.8 that has no power under acceleration. the only code it had was a p0300, i replaced the plugs and wires and nothing, i then replaced the ignition module and the cam sensor under a friends direction but still nothing. when the vehicle is in park it runs great, with the exception of a minor skip. there are no catalyst, egr, or o2 sensor codes so i don't think it would be a plugged up catalytic converter. since i replaced the plugs and wires i no longer get any codes but the car stills falls on its face going down the road. any ideas?
DOCFIXIT
  • 18,828 POSTS
Have you checked fuel pressure? 52-61 psi
JROB77US
yes fuel pressure is good, looks like its the catalytic converter, drove the car with the egr removed and it ran great, of course this is after gas extremely hot gases from the egr melted a hole in the top of the upper intake and i had to replace that before any further testing. the only thing that is still puzzling is why wouldn't it throw an egr or o2 sensor code?
DOCFIXIT
  • 18,828 POSTS
Yes think P0420 would show but CAT is it with that much heat backed up to EGR to melt. Maybe partial blockage and enough function left to keep O2 from setting.
PBMB04
We have a 2002 Impala with the 3.8 v6 engine.
The car also had no pick-up. The problem was the cat. We found out the there was an extented warranty on some models with certain converters.
We had one of those and it saved us plenty.
Could your problem fall in this situation, I hope.
URODRIGUEZ
Where would I find out if there is and extended warranty on my cat converter?
PBMB04
Our Chevy dealer told us when we called about acceleration problem. He needed our vin number for the car to see if our cat was under the warranty by Chevy.
LISAGILPIN
  • 8 POSTS
i changed the cat converter out and now it bogs upon acceleration, its has no codes coming up has great fuel pressure o2 sensors are good why is it bogging?!
STEVE W.
  • 15,158 POSTS
Did you use a factory converter or an after market unit? Was it changed because of a past code?
If the converter was changed out for damage it is possible that some of it could have already broken off and is plugging the exhaust father downstream. You can do a back pressure test using a low pressure gauge in the O2 sensor port, ideally you want to see under 2-3 psi for a good exhaust. Or if you are not in a town you could remove the upstream O2 and see if the bog lessens or goes away.
A sort of quick test would be to hold a piece of paper or your hand over the exhaust and have someone start the car after it was cold. Have them step hard on the throttle and see if the exhaust increases to match the engine. Just be careful as it will get hot fast.
TOM BRADY7
Car sometimes stalls while driving. It is sluggish while accelerating and feels like its losing power.
  • 110,190 POSTS
This can be a couple different things. For example, a weak fuel pump, a plugged catalytic converter, and many other things.
If the check engine light stays on when the engine is running, I suggest having the computer scanned for diagnostic trouble codes. Here is a quick video that shows how it is done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but most times a parts store will check it for free. If the light is on all the time, have that done and let me know the codes which are found. If you find a P0420 as one of the diagnostic trouble codes, then my next suggest becomes very relevant.
Next, and after reading your post, my first suspect is a partially plugged catalytic converter. Take a look through this link:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Here is a link that shows how to test a converter:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Try these things first. If you find the converter is bad, here are the directions for replacement. The attached pictures correlate with these directions.
CATALYTIC CONVERTER REPLACEMENT
Removal Procedure
The three way catalytic converter is serviced by replacing the entire assembly. Always replace the gasket at the front flange when servicing the three way catalytic converter. Never reinstall the original gasket.
1. Raise and suitably support the vehicle. Refer to Vehicle Lifting.
2. Disconnect the heated oxygen sensor electrical connector.
3. Remove the exhaust manifold pipe stud nuts.
4. Remove the catalytic converter bolts.
5. Remove the three way catalytic converter.
6. Remove the heated oxygen sensor. Refer to Heated Oxygen Sensor (H02S) Replacement (H02SI) or Heated Oxygen Sensor (HO2S) Replacement (H02S2) in Computers and Controls.
Installation Procedure
1. Install the heated oxygen sensor. Refer to Heated Oxygen Sensor (HO25) Replacement (H02S1) or Heated Oxygen Sensor (HO2S) Replacement (H02S2) in Computers and Controls.
2. Install a new exhaust manifold pipe gasket.
Notice: Refer to Catalytic Converter Movement Notice in Service Precautions.
3. Install and support the three way catalytic converter.
4. Install the catalytic converter bolts.
Notice: Refer to Fastener Notice in Service Precautions.
5. Install the exhaust manifold pipe stud nuts.
- Tighten the exhaust manifold pipe stud nuts to 32 Nm (24 ft. lbs.).
- Tighten the catalytic converter bolts to 45 Nm (33 ft. lbs.).
6. Connect the heated oxygen sensor electrical connector.
7. Inspect for leaks and underbody contact.
8. Lower the vehicle.
_______________________________________
CHRIS372
While driving my car the check engin light came on and it started to skip and acted like it had no power . When motor is at around 4000 rmp you can hear a ratteling in the motor. Could it be the timing chain needs replaced?
Sep 17, 2020 at 11:51 AM (Merged)
  • 110,190 POSTS
Before we do anything with the timing, have you scanned the computer to see what trouble code is stored in it? It could be a bad coil, plug... (something simple)
CHRIS372
no i have not scanned computer
  • 110,190 POSTS
I recommend starting there. If the check engine light was on, it should give us an idea as to where the problem was coming from. Most parts stores will scan it for free. Have that done and let me know what you find.
ORANSKI
My 1995 impala ss has no power while cold and as soon as it warms up it will stalls and will not start until engine is cold. I have no codes. Any help would be appreciated.
2CARPRO JACK
  • 11,533 POSTS
possibly the ignition system, those engines have a distributor behind the water pump, its driven by the cam. If youve ever had a coolant leak above it it could have shorting issues. They also had bearing problems
ORANSKI
I was thinking it might be a cam sensor. I have to take the same parts off to get to the distributor or the cam sensor. I probably will replace both parts when I do. Thanks for the reply.
MATT PEAY
Drive 5-8 miles then it starts losing power like it’s hitting on 6 cylinders or starving for fuel not for sure which. sometimes I let off on gas and it gets better. sometimes I have to shift down to keep it running as well . Changed wires, plugs, fuel filter, distributor cap rotor pick up everything but carburetor! Please help sure would like to take to car shows.
94 TRANSAM
  • 680 POSTS
Hi Matt, welcome to 2CarPros.
It sounds like maybe your ignition coil is going bad and as it heats up its building up internal resistance and the spark gets weak. Here is a guide on how to test a coil. It is a modern coil not a can style but you test them the same way.
Let me know what you find or if you need help doing it.
Rich
B1THOMAS
My vehicle is a 2000 Chevy Impala LS 3800 V6 with 84,000 miles. It is an automatic transmission. Here is the problem: while I am accelerating, the vehicle often begins to buck for several seconds until I have reached a speed 5 – 10 mph higher then where it began. If I look at the RPMs during the bucking, the needle will be bouncing up and down. The idle of the vehicle appears normal. What is the problem?
The only other problem with the vehicle I know of is a poor ignition wire set that may need replacing. Could that cause the problem? I talked to a repair shop and the individual told me to wait until a light came on because they would be unable to find anything at this time. I am worried that if I wait until a light comes or until the problem worsens, I will have damaged other areas of the vehicle. What are your suggestions?
THANK YOU
Sep 17, 2020 at 11:52 AM (Merged)
SUMDUDE
honestly when the impalas are slow to accelerate, bad gas milage its the Catylic COnvertor gone bad or cogged up. Take it to the dealership. cehvy extended the milage to 8 years or 120,00 mile si believe. ask them to do a back pressure test on the Cat convertor.
