Mechanics
CHEVY NO HEAT
2000 Chevrolet Impala
Heater problem
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic 65000 miles
The blower blows cold air. Thermostat has been replaced. Coolant levels are OK. Both hoses are hot. Fuses are OK. No leaks have been found. Any idea of where we should look next?
Rosann
November 5, 2010.
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
Wrenchtech
Nov 5, 2010.
AD
