2000 Chevrolet Impala Repair Question
Asked on July 15, 2010
2000 Chevy Impala ABS and Traction control warning lights
Electrical problem
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic 118000 miles
I just got my Air conditioning system replaced. After we got into the car and started driving, we noticed the ABS and TRAC OFF lights were on. They were not on prior to getting the A/C repaired. I have already had the hubs replaced within the last year and I am just hoping that maybe there is a wiring harness of something that maybe they had to disconnect and forgot to reconnect when they replaced the A/C. The gasket on the compressor was shot and they replaced that and 2 other components that require replacement when "cracking open" the system.
Thanks for any help you can give.
Answer
Replied on July 15, 2010
If you could get some abs code's i could help get you in the right direction.
Replied on July 16, 2010
We took it in this morning and after about 2 hours they rescheduled us because they couldn't get any codes to show. The comp and the reader were not working together.
Well let me know when they get those code's.
