1995 Chevrolet Impala Repair Question
Topics covered: Distributor, Engine, Sensor.
Asked on January 10, 2006
1995 impala ss has no power and stalls when warm
My 1995 impala ss has no power while cold and as soon as it warms up it will stalls and will not start until engine is cold. I have no codes. Any help would be appreciated.
Answer
Replied on January 10, 2006
possibly the ignition system, those engines have a distributor behind the water pump, its driven by the cam. If youve ever had a coolant leak above it it could have shorting issues. They also had bearing problems
I was thinking it might be a cam sensor. I have to take the same parts off to get to the distributor or the cam sensor. I probably will replace both parts when I do. Thanks for the reply.
