2CarPros - Car Questions & Answers
2000 Chevrolet Express Repair Question
Topics covered: 12 volt, Body, Fuse.
Asked on March 11, 2008
2000 Chevy Express Replicing silinoids
Replied on April 15, 2008
There are two wires going to the solenoid. Connect a volt meter to one of the wires and the other lead to a good ground. You should see 12 volts DC. If not, connect to the other wire and a good ground. If you still don't show 12 volts, check the trans fuse. If it's good, replace the ignition switch. If you do have voltage on the solenoid wiring, replace the solenoid. Push on the shift valve to make sure it's not binding in the valve body.
Tiny Answered by dennyp (expert)
1,879 answers provided
Thank you for your advise. I will try it and let you know of outcome.
Best regards
Tiny Response from ifcmember
2 questions asked
