Transmission fluid drain and fill
CHASJERNIGAN
  • 2005 CHEVROLET EQUINOX
My vehicle is a six cylinder, front wheel drive, automatic with 92,500 miles. I see where the dipstick is, but there is a lot of wires and other obstacles blocking it. The only thing I can think of is putting a jack underneath the transmission and removing the transmission mount. My question is will this work and not damage the the transmission? Is there an easier way? My car has the 3.4L engine.
Friday, September 17th, 2010 AT 6:09 PM
Hi chasjernigan, Welcome to 2carpros
TRANS-AXLE FLUID REPLACEMENT
REMOVAL PROCEDURE
Raise and support the vehicle.
Remove the drain plug and drain fluid. Allow at least five minutes for the fluid to drain completely.
Remove the gasket from the drain plug and discard.
INSTALLATION PROCEDURE:
Install the new gasket on the drain plug.
NOTICE: Refer to Component Fastener Tightening Notice in Cautions and Notices.
Install the drain plug.
TIGHTEN
Drain plug to 40 Nm (30 lb ft)
Make sure vehicle is level.
IMPORTANT: Dexron III automatic transmission fluid is not compatible with this trans-axle. If Dexron III ATF is used, trans-axle failure will result. This trans-axle uses GM T-IV fluid P/N 88900925.
Remove the fluid level indicator located behind the front trans-axle mount.
NOTICE: Do not remove the third gear anchor band bolt located on top of the transmission for checking fluid or adding fluid. Removing the bolt will dislocate internal components and require the transmission to be removed from the vehicle and disassembled for repair.
Add approximately 3.1L (3.3 quart) of GM T-IV fluid to the trans-axle, using the fluid level indicator location.
IMPORTANT: If the check is necessary at a low oil temperature of 30 °-40 °C (86 °-104 °F), perform check using the "COLD" range on the level gauge. However, the fluid must be re-checked at the proper fluid temperature.
Start engine and operate vehicle until trans-axle fluid temperature reaches 60 °-70 °C (140 °-158 °F).
Apply parking brake.
Depress brake pedal and move shift lever slowly through all gear ranges from park (P) to low (liter), pausing for about three seconds in each range. Return shift lever to park (P) range at idle condition.
Pull level gauge out again and check if fluid level is within the "HOT" range.
If fluid is not within the correct level, adjust accordingly:
If fluid is below the "HOT" range, add enough to bring it up to the correct level.
If fluid is above "HOT" range, drain excess fluid.
Install the fluid level indicator.
Cheers!
Saturday, September 18th, 2010 AT 4:21 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,877 POSTS
You will need to raise the car up safely to do the repair here is a guide to get you started on that
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Here is how you service the transmission and check the fluid once you are done.
Here are the diagrams (below) to show you the location of the drain plug and dip stick
Cheers, Ken
Friday, September 29th, 2017 AT 6:14 PM
DANIEL THOMPSON
  • 6 CYL
  • AWD
  • 131,000 MILES
I am trying to find the drain plug for my transmission and where do I fill it up at? Can you help me?
Friday, September 29th, 2017 AT 6:15 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
The drainplug is at the bottom of the transmission use a bucket to catch the fluid.
FELLA808
  • 6 CYL
  • FWD
  • 54,000 MILES
Can you check the auto trans and what fluid to install
Monday, October 22nd, 2018 AT 2:42 PM (Merged)
  • 31,938 POSTS
Hi there,
With the transmission at normal operating them and in park remove the dip stick and check fluid level (see pics) use ATF fluid TIV.
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_164.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic1_17.jpg
Mark (mhpautos)
PURDONIAN
Transmission problem
2005 Chevy Equinox 6 cyl Automatic
howdy, I want to know where the transaxle fill plug is. On top of tranny, side near the dipstick, or do I add the fluid at the dipstick area?
Monday, October 22nd, 2018 AT 2:43 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Yep you should add teh GM T-IV fluid to the transaxle using the fluid level dipstick location.
