2CarPros - Car Questions & Answers
Chevrolet Corvette Repair Question
Topics covered: Ignition coil, Spark, Ignition module.
Asked on August 6, 2007
No Spark
1995 Corvette:
150,000 miles
350 LT1, Manual 6 speed.
Please could someone help. The car won't start. There are no sparks coming from any spark plug wires. I also checked for spark from the ignition coil. But around 11volts are present at the input of the ignition module when the ignition key is turned "on".
I have replaced both the ignition module and ignition coil with no help. The resistance of the ignition coil wire is around 3.3k ohm which is under the specified limit of 5Kohm. The ignition coil module ground circuit is good. The wire coming from the Ignition coil module to the PCM is good. The only thing that is left that I know of to replace is the PCM itself. A abd PCM maybe? And also what I have not satisfactorily done is retreive the trouble codes. It has a 16 pin diagnostic connector which is for OBD-11. But my OBD-11 code reader is only good for 1996 and above vehicles. I tried it anyway and it gave an "error" when I pressed the "read" button.
Sorry it turned out to be a two parts question. How do I retrieve the codes without a reader. I'm hoping any of the codes will tell me why it is not starting.
Thanks in advance.
Enaire
Avatar Asked by enaire
Answer
Replied on August 6, 2007
Find/Inspect/Test the crankshaft position sensor-also the voltage reference on the connector.
Resistance check close to 1kohms -its okay.
Tiny Answered by rasmataz
68 questions asked
Replied on August 7, 2007
1995 corvette
Hi rasmataz,
Thanks for a quick reply. I did what you said. I ohmed the position sensor and it is okay, but I replaced it anyway and I'm still getting no spark. Any other suggestion?
Thanks,
Enaire :cry:
Tiny Response from enaire
1 question asked
Replied on August 8, 2007
You have replaced coil/ICM/CPS dunno if it has a camshaft sensor-if it does check that too, if not could be coming from the computer
BTW did you check for the ref. voltage at the connector on the CPS
68 questions asked
Replied on August 10, 2007
Did you replace the Opti-spark unit?
GWH
Tiny Answered by GWH
2 questions asked
Replied on August 13, 2007
GWH[/quote:4021aa9aa3]
I will try a new Opti-spark unit.
Thanks
1 question asked
