Chevrolet Corsica Repair Question
Asked on October 13, 2007
Cooling fluid leaking
I have a 1994 Chevy Corsica, 113,000 mi. with a 3.1, 6 cly. engine. It has just started loosing coolant fluid from a rubber L shaped drain hose near the firewall. Does this indicate a bad heater core or some other problem? The fluid pours out as long as the overflow tank is up to its marks, then when the overflow tank is empty it slows down. Thanks any help will be usefull.
Answer
Replied on October 15, 2007
check to see if the clamps are tight and that the hose is not busted.
