Coolant temperature sensor
SAMMS21
  • 2007 CHEVROLET COBALT
Engine Cooling problem 4 cyl Front Wheel Drive Automatic
I have a 2007 Chevy cobalt LS with a 2.2 liter ecotec engine, I am having problems with the coolant temperature sensor. I have replaced the sensor twice already and it continues to act up. It will not read when the outside temperature is below 60 degrees Fahrenheit. If I start it from a cold start then drive for a few miles it will read up to 170F° then it will hover around 165 to 170 then it will get stuck on a random temperature in between Then it will read followed by the radiator fan coming on and running constantly. After all of this happens the engine light will come on after a few more miles. Can someone please help me?
Thursday, September 30th, 2010 AT 8:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
This sounds like a stuck thermostat so I will give you instructions on both. Here is a guide for the sensor that will give you and idea on what you are in for when doing the job.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
and
Here is the sensor on Amazon for $9.00 AC Delco
https://www.amazon.com/gp/product/B000CGM9O2/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B000CGM9O2&linkId=805f03af74e6b9da40a401896cac12a2
and the thermostat for $18.00
https://www.amazon.com/gp/product/B000IYT1NK/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B000IYT1NK&linkId=d30fab6bff064f6635c722f18549eae0
Here are some diagrams to help you get the job done on your car (below)
Please let us know what you find.
Cheers
Thursday, September 30th, 2010 AT 8:21 PM
SAMMS21
  • 21 POSTS
I thought I just purchased a faulty sensor but it continued with the same problem
Thursday, September 30th, 2010 AT 8:35 PM
BLUELIGHTNIN6
  • 16,542 POSTS
What type of coolant are you using in system or has it ever been replaced?
Thursday, September 30th, 2010 AT 8:51 PM
SAMMS21
  • 21 POSTS
Coolant has never been replaced, it is the factory orange colored dextron
Thursday, September 30th, 2010 AT 8:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Did more research and it seems to be a common issue with these Cobalts, although I am not finding a solution, however I have found that replacing the coolant sensor and replacing the computer has NOT fixed the issue in the past. Replacing the thermostat is what I am leaning towards, the tstat is around 20 bucks new and rather simple to replace.
Thursday, September 30th, 2010 AT 9:03 PM
SAMMS21
  • 21 POSTS
Thank you for your help even if the thermostat is not the problem I am willing to risk 20 dollars.
Thursday, September 30th, 2010 AT 9:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, normally I don't throw stuff out there but the engine coolant reading is fairly simple set up and from all the research I read online and from what you have described it really leans me to the tstat. Let me know how it goes and if you need steps on replacing the tstat I can get those as well
Thursday, September 30th, 2010 AT 9:15 PM
SAMMS21
  • 21 POSTS
Not exactly sure where the thermostat is on my car until I noticed the diagram you gave. I was once told to follow the upper radiator hose and it should be at the end of that.
Thursday, September 30th, 2010 AT 9:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The thermostat is located behind the engine under the exaust manifold on the drivers side. Just look for the water pump tube and you will find it.
Thursday, September 30th, 2010 AT 9:31 PM
SAMMS21
  • 21 POSTS
Is eat easy to replace? Just unbolt and put the new one in or is it more complicated.
Thursday, September 30th, 2010 AT 9:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Thats the jist of it , getting to it is the ...not really the hard part but the time consuming part. here are some instructions to help ..
Removing the intake manifold cover:
Remove the engine oil fill cap.
Grasp the intake manifold cover by the lower right inboard corner and pull up to disengage the cover from the stud.
Grasp the intake manifold cover by the upper left corner and pull up to disengage the cover from the stud.
Remove the intake manifold cover.
Drain the cooling system.
Reposition the radiator outlet hose clamp at the thermostat cover.
Remove the radiator outlet hose from the thermostat cover.
Reposition the radiator surge tank outlet hose clamp at the thermostat cover.
Remove the radiator surge tank outlet hose from the thermostat cover.
Reposition the radiator outlet hose clamp (1) at the thermostat cover.
Remove the thermostat cover bolts and cover.
Remove the thermostat.
Remove and discard the thermostat cover O-ring seal.
https://www.2carpros.com/forum/automotive_pictures/261618_1_199.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_2_129.jpg
Thursday, September 30th, 2010 AT 9:36 PM
SAMMS21
  • 21 POSTS
Thanks you the thermostat seemed to do the trick it is all fixed, thanks a million guys, this site rocks.
Thursday, September 30th, 2010 AT 9:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Glad we got it fixed we like this site too :)
please use 2CarPros anytime we are here to help.
Cheers.
Thursday, September 30th, 2010 AT 9:49 PM
BABYCODY3
  • 5 POSTS
It fixed my problem too, thanks guys.
Tuesday, December 2nd, 2014 AT 6:37 PM
MARCANTEL_1
  • 107,000 MILES
Changed coolant sensor, didn't help changed radiator hose, still didn't help. Also unhook battery cable to reset only work for 1 day. Any suggestions?
Thursday, September 7th, 2017 AT 2:51 PM (Merged)
What exactly is the code no?
RWWAGONER
  • 2008 CHEVROLET COBALT
  • 74,000 MILES
Replaced thermostat and still am getting check engine light with no temperature reading. The a/c fails to run as well. Think it might be a result of faulty ect sensor reading
Tuesday, April 2nd, 2019 AT 7:55 PM (Merged)
  • 108,170 POSTS
The sending unit should be either on the cylinder head or near the thermostat.
