Mechanics
HEADLIGHTS
Chevrolet Cheyenne
1995 chevy 2500 cheyenne, 180,000 4x4: seems both headlights are out at different times.1 (left)when highbeams are on, the other(right) when there on low. Do the headlights blow totally or are there two lamps 1 for high and 1 for low in the headlight itself and should I consider changing them or is this a wiring problem? Thanks
AD
BUBster
July 21, 2007.
There two different lamps a high and a low more then likly you will have to replce the light first
good luck
Cesar lomeli
Jan 22, 2008.
AD
