2CarPros - Car Questions & Answers
1989 Chevrolet Celebrity Repair Question
Topics covered: Engine, Spark, Air filter.
Asked on July 18, 2010
1989 Chevy Celebrity doesnt start
Engine Performance problem
1989 Chevy Celebrity 6 cyl Two Wheel Drive Automatic 103000 miles
ok went out today to start it it crank but wont turn over i put the hood up checked the air filter and theres gas gettin in it anyone know wat is causin this
Avatar Asked by azcardinals1980
Answer
Replied on July 18, 2010
Cranks and will not start: Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tiny Answered by rasmataz
68 questions asked
