Dome light
MOLZFSNI
  • 2004 CHEVROLET CAVALIER
  • 4 CYL
  • 36,000 MILES
I need to know where is the switch located to turn on and off dome light?
Tuesday, September 23rd, 2008 AT 11:11 PM
RHALL77
  • 3,361 POSTS
The dimer switch is a roll wheel on the headlight switch, which adjusts the cluster lighting as well, click it over and the dome lights will come on.
Wednesday, September 24th, 2008 AT 4:25 PM
ASHEVILLESINGER
Interior problem
2004 Chevy Cavalier Two Wheel Drive Automatic 102000 miles
Just recenlty (last two weeks), when I come to a complete stop in gear the interior ceiling (dome) light comes on and then goes off once car is in motion. I have had the car since June 2009. This happens day or night whether the light switch is in off or on position.
Sunday, May 17th, 2020 AT 11:01 AM (Merged)
HMAC300
  • 48,601 POSTS
You could have bad door switches that are moving when you start /stop. Or a relay or if you have automatic things that operate the door lights. Shut all door then try to pull on them one at a time that should show you which switch is bad when the lights come on..
RSHAWS
  • 1990 CHEVROLET CAVALIER
The dome light is shorting out and I want to disconnect it w/out having to pull the fuse (and disabling whatever else is tied to that fuse). It keeps running the battery down.
E40WATER12
  • 522 POSTS
Pull the bulb out, Or pull the wiring harness connector from the dome light switch underneath the dash. Also if youre battery is draining current, U could also have youre alternator could have burnt out on you.
