Mechanics
CHEVY IGNITION COIL PACK
2004 Chevrolet Cavalier
Other Category problem
2004 Chevy Cavalier V6 Two Wheel Drive Automatic 88000 miles
I have 2004 Chevy Cav 4 cyl had a major miss and found the coil pack to be bad, I replaced the coil pack and it solved the problem now 2 weeks later acting the same way, I did notice a lot of black soot on 2 of the cylinders what could cause the coil pack to goo bad that quickly?
Storkie
November 30, 2007.
Did you check if it s the same cylinder that misfiring
What are you getting for codes
BMRFIXIT
Nov 30, 2007.
Yes it is the same 2 that are missfiring--the codes are showing random misfire and show bad coil pack it is hard for me to believe that 2 coil packs going bad in 2 weeks don't know what would cause it
Storkie
Dec 1, 2007.
It s very rear to see that
Did you use used parts +
Check the module
BMRFIXIT
Dec 1, 2007.
The parts were used a module came with it. But even so its hard for me to believe 2 coil packs going bad in the space of only 2 weeks I just thought maybe there was something causing the coils to go bad before I wasted more money on another coil pack
AD
Storkie
Dec 1, 2007.
THIS IS A 50 /50 chance you take with used parts
very uncommon but !
Dont they give you at less a month warr!
BMRFIXIT
Dec 2, 2007.
Unforutanetly it was bought at a junk yard--48 hr return only
Storkie
Dec 2, 2007.
AD
