Mechanics
CHEVY CLUTCH MASTER CYLINDER
2001 Chevrolet Cavalier
Transmission problem
2001 Chevy Cavalier 4 cyl Front Wheel Drive Manual
How do you bleed the clutch master cylinder, I have tried every which way. Thank's end advance.
Charles Detharidge
December 15, 2008.
I would first let it gravity bleed for a while then try it and see if you have a good pedal. Make sure to keep the master cylinder full of fluid. If that doesnt work, have someone press the clutch down and hold it down while you open the bleeder
Rhall77
Dec 16, 2008.
Thank's very much, I think the problem was slave cylinder leaking off.
AD
Charles Detharidge
Dec 17, 2008.
AD
