power window motor
2002 CHEVROLET CAVALIER
115,000 MILES • 4 CYL • FWD • AUTOMATIC
PASHMORE6
How do I replace the power window motor on rear driver side?
Aug 2, 2010 at 9:11 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
Here is a guide that will walk you through the etps with instructions in the diagrams below to help you on your car.
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
Aug 3, 2010 at 10:51 AM
LINDA1629
Can you please tell me how much you think it would be to replace the passengers window motor/regulator. The window does not budge when you want to close it. Thanks a bunch.
Apr 16, 2020 at 11:45 AM (Merged)
BUZZSAW
  • 1,198 POSTS
[quote:992e11fc43="Linda1629"]Electrical problem
2002 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 100000 miles
Can you please tell me how much you think it would be to replace the passengers window motor/regulator. The window does not budge when you want to close it. Thanks a bunch.[/quote:992e11fc43]
2-300 bucks
AJDEFOE
The front driver-side power window motor is in need of replacement. I can see that it is riveted on and I can drill those out. My problem is where the regulator (scissor-type) and motor attach: I have read that there is a spring mechanism that needs to be dealt with using a special tool. How do I detach the regulator from the motor safely and then attach a new motor correctly?
MERLIN2021
  • 17,250 POSTS
WINDOW MOTOR Removal & Installation 1. Pull inside door handle to full open position. Push in on door handle pull cup, while prying out at top with flat-blade tool. Pull up on door handle pull cup to remove. 2. On front doors of hardtop models, remove power door lock switch and power window switch. See WINDOW & DOOR LOCK SWITCHES . 3. On front doors of convertible models, remove power door lock switch. See WINDOW & DOOR LOCK SWITCHES . 4. On all models, remove upper trim finish panel. Remove door trim panel lower screws. Remove door armrest. Remove door panel and set aside. 5. Remove water deflector enough to access motor/actuator assembly. Disconnect motor/actuator assembly electrical connector. Remove motor/actuator assembly bolts. Remove motor/actuator assembly. 6. To install, reverse removal procedure. Tighten motor/actuator bolts to 53 INCH lbs. (6 N.m). © 2008 Mitchell Repair Information Co., LLC. Page 1 of 1 POWER WINDOWS -2000 Chevrolet Cavalier 4/24/2009 http://www.ondemand5.com/mric/common/asp/printart.aspx
Not on this one. More info here:
https://www.2carpros.com/how_to/power_window.htm
Convertibles do have a spring mechanism.
AJDEFOE
Thanks for the reply, but you did not address the spring issue. Where exactly is this spring and how do I keep it from releasing when I disconnect the motor from regulator? I want to replace just the motor, not the regulator too. Also, the first link you posted did not work.
MERLIN2021
  • 17,250 POSTS
I thought I did address the spring, non in yours! The directions are specific to your car. The first link is dead, it only shows where I got the info! You do NOT need to remove the regulator on yours... You do have to remove the regulator because it has a coiled spring on convertibles.
KATML91
The motors in my windows are bad. They are the original motors for my car. About two months ago we tried to get the motors out to replace them with new ones, but the old motors are stuck to the gears. Any suggestions as to how I can get the old motors out to replace them with the new ones?
HMAC300
  • 48,601 POSTS
they are replaced as an assembly meaning motor and regulators. I think they are available online for around $60 each dorman makes them.
KATML91
Thank you so much! You actually responded to two of my questions on here. I am going to give both a try. It will save me from having to find a way to get a whole new car, especially with the other question about the fuel lines. I appreciate it. :)
4005SIW
Is there a procedure you could send me an attachment of? Can get a used motor for $40 and haven't found a good labor price in zip 48912.
Apr 16, 2020 at 11:46 AM (Merged)
WINDOW MOTOR
On front doors of hardtop models, remove power door lock switch and power window switch. On front doors of convertible models, remove power door lock switch. See WINDOW
CADIEMAN
  • 3,544 POSTS
how do u know its the motor??????????
4005SIW
Not sure it's the motor yet. Just beginning on this.
CADIEMAN
  • 3,544 POSTS
hold the switch to go down.then bang on the panel.if the motor turns on youll know its the motor.
FIXITMR
  • 9,990 POSTS
motors dont go bad much but overheat sensors do. you can dissasemble motor and bypass sensor and it should work again.
ERIC1980.EB
can someone tell me what exactly i need to replace in my power window motor on my cavalier trying to rebuild it and even after getting new brushes for it and installing them still weak and not enough power to move the regulator very much at one time? Could it be the spindle or magnet? any pointers will help.... thank you. p.s. i have tested everything and did replace the switch cause the other side was not working and it was the switches and now the drivers side still isn't working, at my wits end with this..... time to buy a new motor or is it possible to make it work?
SATURNTECH9
  • 30,869 POSTS
I have never tried rebuilding a motor there reasonable to buy a rebuilt one try www.rock.com or amazon for a better price on one then the auto parts store.I would just replace it if its not the brushes then you have a stator or magnet issue.
CARADIODOC
  • 34,309 POSTS
Look for a thermal cutout inside the motor. I think they're a glass bulb with a set of contacts, but Wrenchtech mentioned some other device that I can't remember. The contacts in those glass bulbs become pitted and add resistance to the electrical circuit. They cause more problems than they prevent. You can prove it by temporarily bypassing it with a jumper wire. They do that on a regular basis at one local used car dealership, but I would never recommend doing that on a permanent basis. Lawyers and insurance investigators love to find modifications that could lead to problems.
ERIC1980.EB
Awesome all is helpful! I will take that son of a gun back apart and look to see if I can find what you are talking about and if not well guess I'm going to rock.com thanks guys!
SATURNTECH9
  • 30,869 POSTS
Your welcome keep us posted.
ERIC1980.EB
So thanks guys I did have to end going with a new window motor and rockauto was the place to get it only gave 34 bucks for it thanks a bunch for you info! Greatly helped me a lot thanks again!
CRHEYNE
I got an answer that said to remove the door shell. On the Cavalier, once the door panel has been removed, there is nothing but sheet metal and a few holes through which some of the inner workings can be seen. I don't see any way to remove this sheet metal. Is the door shell the outer piece? On this site, the illustrations on R&R the power window motor show cleqr access to the motor, not so on the Cavalier. HELP! Should I just throw in the towel and take it all to a shop?
  • 54,350 POSTS
dont give up, some access to the window motors can vary, if the inner panel can not be removed you must remove the outter shell, it is easier than it looks. Please let me know how it goes.
SATURNTECH9
  • 30,869 POSTS
Your welcome thats what were here for glad to hear you got the window working again.
D5NUKE
  • 61 POSTS
When I called it a door shell I was refering to the door panel itself. Sorry about that.The access holes in the door seem small but with a little patience you can get the job done.
good luck
CRHEYNE
How do I get into the inner door to remove and replace th epower window motor on my "96 Cavilier? I got the door panel off and switch disconnected but can't figure out how to remove the motor.
D5NUKE
  • 61 POSTS
To change the power window motor .. Remove the door shell of course
You will see the motor for the window .. Unplug the power.
The motor is actually riveted in so you need to drill out the rivets. You can drill these out through the door itself use a larger bit so you can see the rivets holding the motor to the regulator.There is 3 rivets.
CAUTION: Sure you support the window before you drill out the rivets as the window will fall when the motor is removed.use tape or a wedge to hold it up.
Dont use to large of a bit to drill the rivets holding the motor to the regulator as you will need to use the holes in the regulator for the new motor.
Remove the old unit .
Then install the new motor with self tapping screws . Plug in the power.
Good luck ..
