Please run some tests and get back to us so we can continue helping you.
Best, Ken
Saturday, December 10th, 2016 AT 11:40 AM
CHOPPER120
MEMBER
Thank you for all of your guys help I had to drop the tank to get the pump out like the video showed but glad I did because the car has never run better.
Sunday, December 11th, 2016 AT 2:53 AM
HMAC300
MECHANIC
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
SPONSORED LINKS
Sunday, December 11th, 2016 AT 4:23 PM
CRROLAND92
MEMBER
2000 CHEVROLET CAVALIER
120,000 MILES
My 2000 Chevrolet Cavilier keeps stalling as I drive it. All I have to do is restart it and then it will go again untill it stalls once more. What is causing this and how can it be fixed?
Saturday, October 10th, 2020 AT 10:59 AM
(Merged)
MECHANIC
Is the check engine light on?
(Merged)
CRROLAND92
MEMBER
No the check engine light is not on.
(Merged)
MECHANIC
Look for basics like a vacuum line off. Make sure there is nothing disconnected. The throttle plate may be dirty not allowing air into the motor as well.
(Merged)
CRROLAND92
MEMBER
Ok thanks. Ill check them out
(Merged)
MECHANIC
Get back to us with your results
(Merged)
LSTORY
MEMBER
1 POST
2.2L
4 CYL
FWD
MANUAL
230,000 MILES
Ran out of fuel yesterday, now it won't start. Put fuel in, checked fuel pump(you can hear it turn on), checked relay and fuse, no fuel going to injectors. If we put fuel in the injectors it starts but dies once it uses it. It also starts with starting fluid in the intake.
SPONSORED LINKS
(Merged)
MECHANIC
Although you hear the pump run, it may have been damaged. First, check to make sure the fuel filter didn't pick up dirt and plug. If it is good, see if there is pressure to the filter. If there is no pressure and you hear it run, remove the pump, make sure there are no blockages, and replace if it is clean.
(Merged)
JJHART25
MEMBER
4 CYL
2WD
MANUAL
135,000 MILES
Car shuts off usually when I brake, it runs bad whenever its hot outside or use AC, I recently did a tune up, oil change, and replaced the o2 scentor.
(Merged)
PHANTOM01
MEMBER
Could be IAC, check air filter, head gasket could be going also. Need more info
(Merged)
JJHART25
MEMBER
It was the map sensor. Its all fixed and running great, thanks for the help though. =)
(Merged)
MCGLONEINC
MEMBER
1 POST
4 CYL
FWD
AUTOMATIC
128,000 MILES
Alright, so we get our heater fixed in our car and, on our way home, (on the same day it was fixed) it dies while driving down the road. Pulled over, turned off engine, restarted engine turned off heat, and drove the rest of the way home, just wonder what could possible be the problem. Oh and the car worked fine before the heat was fixed.
Saturday, October 10th, 2020 AT 11:01 AM
(Merged)
BILLYMAC
MECHANIC
Hi
here is a thought. Unplug your air compressor plug and drive with the heat on. If car still dies write back if not bad a/c comp.
Another possibility is the iac motor is failing
(Merged)
GRANDMA36
MEMBER
4 CYL
FWD
AUTOMATIC
101,393 MILES
My car has begun stalling while I'm driving. At first, I could keep it going if I keep pumping the gas; eventually it would run normally again. Yesterday it began stalling and I couldn't get it to run normally again. I kept pumping it for several miles. When I gave up and stopped the car, it smelled like something was burning. How do I find out what this problem is without a lot of trial and error expense? Thank you for your help.
Regards,
Lola Foote
Saturday, October 10th, 2020 AT 11:04 AM
(Merged)
LEGITIMATE007
MECHANIC
Well the first thing we are going to want to do is a fuel pressure check and a spark/ignition check. I will give you some info on how to do that, Now if I were to make an educated guess, I would say, the fuel pressure regulator. Throttle position sensor, or there is something wrong with the flow of air into the system, but first we need to check those first two items.
