1998 Chevy Cavalier replacing 98 cavalier engine with a 97
1998 CHEVROLET CAVALIER
THOMASOAKLEY
Engine Mechanical problem
1998 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
when doing motor swap, need to know if i change intakes (and the bracketry on the front of the motor) to convert the engine coolant hoses...are there any other specs needed other than changing flywheel & pressure plate from auto to standard?
Furthermore, is it possible to avoid changeing the intakes, perhaps by swaping the wiring harness & mabye the cpu? Engines appear identical except for placement of connection hoses, etc. Any tips or advice?
May 30, 2010 at 12:13 PM
