Mechanics
CHEVY DIES ON ME
1997 Chevrolet Cavalier
Engine Performance problem
1997 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 140, 00 miles
replaced fuel pump, fuel filter, fuel injectors, plugs and wires, coil, ignition module, alternator and battery, water pump
car dies on me and is a misfire on cylinder 3
when I found missfire on cylinder 3 I replaced plugs and wires first, then coil, then ignition module all of which autozone and a mechanic said would fix it.
no fuel pressure check has been done
don't remember what plug looked like on 3 cylinder
mechanic done injectors dont know if they checked it
but after he got done with it everything went wrong
Chrisl67
June 11, 2008.
OK, Did the Missfire in the #3 cylinder prompt you to do all that has been done?
What did the #3 cylinder plug look like? If you haven't pull it now and see what it looks like.
Have you have the fuel pressure checked?
When the Injectors were replaced did you check the Injector Harnesses?
Obxautomedic
Jun 11, 2008.
