Ive had this problem for about 2 mos. now and finally it quit...my car will crank but wont start.. I had it looked at by a pro. and he cranked it until the battery died and when he went to recharge it the car started after 2 days of cranking.... now he cant tell me what is wrong because it was then working.. however now it has happened again and it wont start so rather than tow it... ill try it myself.. he told me it had no spark at the time.. and it may be the crankshaft sensor.. or possibly the ignition module so I want to find out how to 1. check if there is a spark and 2. replace the crank sensor if it is bad... but I cant locate it... and if there is spark do you think it could be a fuel pump... the car runs very strong when it does start...no hesitation at all...or rough idling....
Jul 8, 2008 at 6:07 AM
