2CarPros - Car Questions & Answers
1992 Chevrolet Cavalier Repair Question
Topics covered: Coolant, Radiator, Transmission.
Asked on April 15, 2008
Chevy overheating
Engine Cooling problem
1992 Chevy Cavalier 4 cyl Front Wheel Drive Manual 177000 miles
I have to fill radiator with water every 15 miles or so because water/coolant is pouring out of the bottom of the car. I checked hoses and radiator, no leaks. The water/coolant is coming out of where the fly wheel is by the transmission. No oil leaks, no water in the oil, compression is about 15% less than it was, and it is continuously overheating. If this is a freezeplug, where is it located and can you give me a diagram?
Avatar Asked by sarahabts
Answer
Replied on April 16, 2008
you will have to pull the transmission if you can see anything above that is leaking. you may also have a cracked block.
Tiny Answered by rhall77
6 questions asked
