I bought my blazer early this year, used. Within the last month i have been having problems with it starting. It started with just occasionally not starting right away, i had to turn the key two th=o three times. Now, it has taken 20 minutes or more for it to start. it was exactly a week within episodes. when you turn the key everything works fine and i believe i hear the fuel pump. we have changed the relay swich and are wondering if we should change the ignition switch. I've heard of other blazer owners having this same problem. help
Dec 18, 2007 at 5:39 PM
