My blazer does not start, it will crank over and want to, but it won't. If I dump starter fluid or gas in th air intake thingy it will fire up and stay running till all the gas has been burnt up. (like10-15 seconds) I have checked the fuel pressure which is reading between 60-65, however when you shut the vechile down after trying to turn it over it drops down to 40, could this be a fuel regulator problem? I have also used a noid to check the injectors and the wire seems fine, therefore I do not think it is elecrical. I have replaced the temp sensor as well as the ignition switch wires which is what the problem was the last time. Any information would be a great help, I have left this vechile sitting or the last year because of the problem.
Thanks,
Ellielynn
Thanks,
Ellielynn
May 16, 2008 at 6:29 AM
