Mechanics
CHEVY TURN SIGNAL PROBLEMS
1998 Chevrolet Blazer
Electrical problem
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic 89000 miles
My flasher will not stop clicking after my turn signals shut off. Do I need to replace the turn signal lever?
Fng605
June 7, 2009.
Have you replaced the flasher itself? Let me know.
Racefan966
Jun 15, 2009.
I have not replaced anything at this point. Will the flasher do this if it goes bad?
AD
Fng605
Jun 15, 2009.
It could depends on what type of flasher it is. Do you have a digital multi meter? I need you to do a simple test. Find the flasher unit it is behind the right side of the dash. Now there are 4 wires to it. Turn the turn signal on and check the light blue wire for power let me know what you find. Now check the purple wire and see if it has power let me know what you find. Now turn of the signal switch and check the blue wire again does it still have power? If it still has power after the switch has been turned off the the switch is sticking and needs to be replaced. Hope this helps. Thanks.
Racefan966
Jun 16, 2009.
I did the testing you suggested and found the Lt. Blue wire had power with the signal on or off and the purple wire had no power reading either way. You stated I have to replace the switch, Do you mean I have to replace the entire signal lever assembly? Thank you for your assistance.
Fng605
Jun 19, 2009.
OK it looks like the turn and hazzard is all built into the turn signal switch assembly. The best I can tell this will need to be replaced. Here is pic of how it comes. I would also check salvage or wrecking yards for a better price.
http://www.2carpros.com/forum/automotive_pictures/249564_102883_1.jpg
Racefan966
Jun 20, 2009.
AD
