1995 Chevrolet Blazer Repair Question
Asked on March 9, 2009
1995 Chevy Blazer 2WD/4WD Issue
Noises problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic 95,000 miles
I was driving on the highway when I heard and felt a high frequency vibration coming from the transmission. As I slowed down the whirring became a clicking sound. When I switched to 4wd the noise and vibration went away. Wehn I switched back to 2wd it happened again... Ideas?
Answer
Replied on March 9, 2009
I would first check the CV joints on both the front and rear drive shafts. Is the fluid in the transfer case full? Note; A CV joint can be bad, but many times you can't shake them to check for wear like you can a regular U-joint. Please advise.
