1987 Chevrolet Blazer
Electrical problem
1987 Chevy Blazer 6 cyl Two Wheel Drive Automatic
my blazer want turn over all day way. I put a new button and ignation module. The starter and altnator is in good condition. What can be my problem
June 1, 2009.
Hello, I'm not exactly sure about your problem. If your saying the starter won't even crank, we can check your starter circuit? If your saying it cranks good but won't start, that is another issue. Have you done any basic testing? Have a helper crank it, while you check for spark at the plugs and injector pulse. Check fuel pressure. Your obd1 can you check for codes?
Jun 1, 2009.
