Speedometer problem
RPRASCHER
  • 2010 CHEVROLET AVALANCHE
  • 5.3L
  • V8
  • 4WD
  • 92,000 MILES
My speedometer drops ten to fifteen mph while driving at highway speed then returns. This also will shut off my cruise control if it is on. The cruise also will shut off without the speedometer dropping. I have had this to a mechanic and drove it with a reader connected. It showed an upward spike in the speed graph. We were thinking the speed sensor?
Do you
have the same problem?
Thursday, May 4th, 2017 AT 7:56 AM
HMAC300
  • 48,606 POSTS
Then check to see if cluster is getting signal it may be a wiring issue or the dash needs to be rebuilt. If it is not getting a signal replace the speeds ensor here is the location of the sensor and a video of the job being done for the cluster replacement with a rebuilt unit.
https://youtu.be/_HEC44xENxw
Thursday, May 4th, 2017 AT 12:26 PM
RPRASCHER
I have had a mechanic check all the wiring and sensors we swapped out the cluster tht fixed it, thank you so much for the video.
Thursday, July 13th, 2017 AT 2:54 PM
HMAC300
  • 48,606 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Thursday, July 13th, 2017 AT 3:03 PM
AZRAGE52
  • 2005 CHEVROLET AVALANCHE
Electrical problem
2005 Chevy Avalanche V8 Two Wheel Drive Automatic 75k miles
i change my battery in my truck, as a result of this my truck, speedometer went out, only work every now and then. Also my truck sometimes doesnt start. I check the battery cables and they are both tightly installed. Do you have any idea?
Tuesday, July 14th, 2020 AT 4:50 PM (Merged)
  • 108,005 POSTS
HAve you tried to reset the computer by disconnecting the battery for about 5 minutes then reconnecting it to see if that resets it?
AZRAGE52
Yes I have tried that, with no luck
MDYKE
  • V8
  • 113,000 MILES
Mt speedometer shows from 80 to 120 while sitting still. This after using the cruise control. What could cause this?
  • 108,005 POSTS
Have the vehicle speed sensor (VSS) checked. If it is good, then there is a good chance the cluster itself may be bad.
Let me know what you find.
GOODER
  • 2003 CHEVROLET AVALANCHE
  • V8
  • 4WD
  • 96,000 MILES
My speedometer is pegged at 120mph and won't move. I have already replaced the speed sensor but that was not the problem. Is there a part to be replaced? I can't seem to find anything on the internet.
RHALL77
  • 3,361 POSTS
Most likely you will have to replace the IP cluster. You can go to your dealer and have a sweep test performed on it to see if it will start working. But I think you need a cluster
RHALL77
  • 3,361 POSTS
I would suggest buying one form a dealer, they have a warranty and will stand behind it if something goes wrong. I have had nothing but problems with parts purchased off the internet
CHEVYP2P
  • V8
  • 4WD
  • 89,446 MILES
My speedometer is not working right the speedometer gauge is giving me a wrong reading. Does any one knows how to fix if
Tuesday, July 14th, 2020 AT 4:52 PM (Merged)
87BANSHEE
  • 15 POSTS
You need to replace the instrument panel cluster. This is a common problem with these trucks. You will have to get it programmed at a dealership.
DIP
  • 2004 CHEVROLET AVALANCHE
Electrical problem
2004 Chevy Avalanche V8 Two Wheel Drive Automatic
SPEEDOMETER NOT WORKING
RHALL77
  • 3,361 POSTS
Is it stuck in a certain position. You may have a bad cluster causing it? The stepper motors are known to go bad in them
JAIME818
  • V8
  • 101,000 MILES
My speedometer is not working. I changed the speed sensor. Still does not work!
KYTERRYLEE
  • 8 POSTS
You need to call a dealership and make sure there are no recalls or TSB's. If there is not, you can find used instrument clusters for not much $ and you shouldn't pay more than an hours labor to have it replaced. Hope this helps!
ANTHONY HALL
  • V8
  • 4WD
  • 81,000 MILES
All my gauges are not working. The speed odometer, tach, fuel, temp etc won't register. Has a fuse that controls all these gauges blown or is this more serious? Thank you
SAILOR.JERRY
9 times out of 10 it is the cluster that has gone bad here is a video that can help you see how to fix the problem.
KYTERRYLEE
  • 8 POSTS
Check with your Chevrolet dealer on the cluster as well, it fixed my car. This site rocks
