1998 Chevrolet Astro Repair Question
Topics covered: Engine, Check engine light, Distributor.
Asked on June 10, 2010
1998 Chevy Astro backfires runs rough sounds like chitty ch
Engine Performance problem
1998 Chevy Astro 6 cyl Two Wheel Drive Automatic 250000 miles
was running fine shut it off started again drove 2 blocks went to accelerate and acted like not getting gas then took off but running like it is not firing on all cylinders changed the distributor cap as we found it was loose had broken hold on one ear. changed the plugs still same problem HELP please
Answer
Replied on July 19, 2010
Did you replace the plug wires? Have you checked fuel pump pressure? Is the check engine light coming on?
