Mechanics
CHECK ENGINE LIGHT CODE IS THERMOSTAT
2001 Mitsubishi Montero • 198,000 miles
My check engine light is on and I have taken it to my local mechanic and he has coded the vehicle to be a bad thermostat. He has replaced the thermostat and reset the light. After driving a short distance the check engine light has reappeared and is coding thermostat failure again. They have checked the vehicle temperature via a manual temp gauge and the vehicle is registering a motor temp well within it required limits. The temperature gauge on the vehicle dash board is reading the vehicle to be running hot. All the test that the mechanic has run shows the motor to be operating in the correct temperature range. What to do next? Steve
Szimarino
June 13, 2013.
Try replacing your engine coolant temp sensor
Hmac300
Jun 14, 2013.
AD
