Mechanics
CHECK ENGINE LIGHT
1992 Ford Taurus • 98,000 miles
Check engine light is staying on til engine is turned on. All fluids are good & at proper levels. There are 2 bulbs (brake and turn signal bulbs) which recently burned out. Could this cause the check engine
Stacie9762
May 29, 2013.
Check your instrument panel ground it may be causing that.
Hmac300
May 29, 2013.
