Transmission Problems
2001 MAZDA MILLENIA
177,000 MILES
CHAZ1039
Car will not shift from first to second. The RPM's rev up without shifting. The car is 6cyl w/auto transmission.
Jan 2, 2012 at 2:40 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
sounds like time for a rebuild. check fluid if brown change it , but i think it's to late. your seal or clutch may be bad.
This guide can help us fix it
Jan 2, 2012 at 3:17 PM
KHLOW2008
  • 41,814 POSTS
Check for trouble codes. You might have a faulty solenoid.
Jan 2, 2012 at 8:37 PM
CHRISTINEC
my car threw out two codes yesterday, P1250 and P1522 how do i go about fixing these problems?
Apr 16, 2020 at 11:35 AM (Merged)
KHLOW2008
  • 41,814 POSTS
DTC P1250: PRESSURE REGULATOR CONTROL (PRC) SOLENOID VALVE CIRCUIT MALFUNCTION
Condition
DTC is set when input signal from PRC solenoid valve to Powertrain Control Module (PCM) is low when ignition is on. This circuit is monitored once per ignition cycle. MIL will not illuminate. Possible causes are:
PRC solenoid valve malfunction.
Open or short circuit between PRC solenoid valve and PCM.
Open circuit between PRC solenoid valve and main relay.
PCM malfunction.
Diagnosis & Repair Procedure
1. Check for related service bulletins. Repair as necessary and go to next step.
2. Turn ignition off and on. Check for DTCs. If DTC P1250 is present, go to next step. If DTC P1250 is not present, problem is intermittent.
3. Disconnect vacuum hose between PRC solenoid valve and intake manifold at
PRC solenoid valve. Using vacuum pump, apply vacuum to PRC solenoid valve
for 5 seconds. If vacuum holds for 5 seconds, go to step 5 . If vacuum does not
hold for 5 seconds, go to next step.
4. Turn ignition off. Disconnect PRC solenoid valve connector. If vacuum holds,
repair short in Green/Black wire between PRC solenoid valve connector terminal "B" and PCM connector terminal No. 1B. Go to step 10 . If vacuum does not hold, replace PRC solenoid valve and go to step 10 .
5. Disconnect PRC solenoid valve connector. Check for damaged or corroded PRC solenoid valve connector terminals. Repair as necessary, and go to step
10 . If connector terminals are okay, go to next step.
6. Measure resistance between PRC solenoid valve terminals. If resistance is 36-40 ohms, go to next step. If resistance is not 36-40 ohms, replace PRC solenoid valve and go to step 10 .
7. Turn ignition on. Measure voltage between PRC solenoid valve harness connector terminal "A" (Red/Black wire) and ground. If battery voltage is present, go to next step. If battery voltage is not present, repair open in Red/Black wire. Go to step 10 .
8. Disconnect appropriate PCM connector. PCM is mounted in front of center
console, under radio. Check for damaged or corroded PCM connector terminals. Repair as necessary, and go to step 10 . If connector terminals are okay, go to next step.
9. Reconnect PRC solenoid valve connector. Turn ignition on. Measure voltage
between PCM harness connector terminal No. 1B (Green/Black wire) and ground. If battery voltage is present, go to next step. If battery voltage is not present, repair open in Green/Black wire between PRC soleniod valve and PCM.
10. Reconnect all connectors. Turn ignition off and on. Check for DTCs. If DTC P1250 is present, replace PCM and go to next step. On vehicles equipped with immobilizer system, reprogram ignition key identification numbers. If DTC P1250 is not present, go to next step.
11. Cycle ignition from off to on. Check for DTCs. If any other DTC is present, go to appropriate test.
DTC P1522: VARIABLE RESONANCE INDUCTION SYSTEM (VRIS) SOLENOID VALVE NO. 2 CIRCUIT MALFUNCTION
Condition
DTC is set when Powertrain Control Module (PCM) detects low input voltage from VRIS solenoid valve No. 2 system with ignition switch on. This is a continuous monitor. MIL will not illuminate. Possible causes are:
VRIS solenoid No. 2 malfunction.
Open or short circuit between VRIS solenoid valve No. 2 and PCM.
Open circuit between VRIS solenoid valve No. 2 and main relay.
PCM malfunction.
2. Turn ignition off and on. Check for DTCs. If DTC P1522 is present, go to next step. If DTC P1522 is not present, problem is intermittent.
3. Disconnect vacuum hose between VRIS solenoid valve No. 2 and intake
manifold. Using vacuum pump, apply vacuum to VRIS solenoid valve No. 2. If
vacuum holds for 5 seconds, go to step 5 . If vacuum does not hold for 5 seconds, go to next step.
4. Turn ignition off. Disconnect VRIS solenoid valve No. 2 connector. If vacuum
holds, repair short to ground in Brown/Yellow wire between VRIS solenoid
valve No. 2 and PCM connector terminal No. 1AE. Go to step 10 . If vacuum does not hold, replace VRIS solenoid valve No. 2 and go to step 10 .
5. Disconnect VRIS solenoid valve No. 2 connector. Check for damaged or
corroded VRIS solenoid valve No. 2 connector terminals. Repair as necessary,
6. Measure resistance between VRIS solenoid valve No. 2 connector terminals. If resistance is 38-42 ohms, go to next step. If resistance is not 38-42 ohms, replace VRIS solenoid valve No. 2 and go to step 10 .
7. Turn ignition on. Measure voltage between VRIS solenoid valve No. 2 harness connector terminal "A" (Red/Black wire) and ground. If battery voltage is present, go to next step. If battery voltage is not present, repair open in Red/Black wire between VRIS solenoid valve No. 2 and main relay. Go to step
10 .
8. Turn ignition off. Disconnect appropriate PCM connector. PCM is mounted in
front of center console, under radio. Check for damaged or corroded PCM
9. Reconnect VRIS solenoid valve No. 2 connector. Turn ignition on. Measure voltage between PCM harness connector terminal No. 1AE (Brown/Yellow wire) and ground. If battery voltage is present, go to next step. If battery voltage is not present, repair open in Brown/Yellow wire between PCM and VRIS solenoid valve No. 2. Go to next step.
10. Reconnect all connectors. Turn ignition off and on. Check for DTCs. If DTC P1522 is present, replace PCM and go to next step. On vehicles equipped with immobilizer system, reprogram ignition key identification numbers. If DTC P1522 is not present, go to next step.
YANCY JORDAN
I was driving home from work and I came to a complete stop at a stop light and when I took off the car never down shifted into first it stayed in drive. So I pulled over to check the fluid and it was fine, I put the car in reverse and it would only rev up to about 1500 rpm and just stall with no movement, I put the car back in drive and it did the same thing( only taking off in drive). If I put the car in neutral or park and rev it up it slowly gains rpms but I can hear a whining noise( not the supercharger) and smell the clutches inside the trans getting hot. When put into neutral and push the car back and put the shifter in reverse while rolling backwards it will roll about 5 ft then it will lock up the front wheels like I was pushin the breaks. Also while in neutral and when I rev it up it acts like it wants to move forward. Any time I put it in reverse it hits real hard but only stalls and no movement, kinda like a stall converter minus the movement! Anyone have a idea on what it may be. Broke internals( drum) ? Shift cylinoide? Speed sensor? Help please
HMAC300
  • 48,601 POSTS
have a trasn guy lok at it, could be anything inside it bad, if fluid is dark brown or black pretty much clutch burned/seals etc.
