Mechanics
CAR WONT CRANK WHEN IGNITION TURNED
1994 Honda Civic • 200,826 miles
Hello. I have a standard 1994 Honda civic hatchback cx. I was driving my car and parked it. When I returned it would not start. I have looked at it myself and am puzzled. I used a volt ohm meter and tested every possible fuse, and they are all good. When I turn my key to the on position, there is power, when I turn it further to the start position there is nothing and it will NOT attempt to crank. I jumped the started to start the car and it runs for only a few seconds and then it looses fuel pressure. I have to disconnect the battery and reconnect it again for the fuel pump to kick back on. Any ideas? All help will be very much appreciated. Thank you
Natemfhunter
July 24, 2013.
Check the ignition switch. Seems it is bad.
KHLow2008
Jul 27, 2013.
AD
