Mechanics
CAR WILL NOT START CRANK BUT NOT START
1998 Nissan Maxima • 234,528 miles
I have replace a lot of things on this car. 1 new fuel pump 2. New Spark plugs 3. New ignition coils 4. Fuel pump relay 5. Ignition relay There are two other sensors that I also replace. The car cranks and runs about 3 sec and then stops. It seems to not be getting gas. Is there a fuel cut off switch on this car and if so where, could the knock sensor be the cause?
Albert lee
August 22, 2013.
I'm sure you had to have tested the fuel pressure before replacing all those parts.
What is the fuel pressure now?
Wrenchtech
Aug 22, 2013.
AD
