Heater not working properly?
GRADY PAYNE
  • 2005 DODGE CARAVAN
  • 3.3L
  • 6 CYL
  • 193,000 MILES
I have replaced filled fluids, flushed heater coil, and I still do not have heat. What do I do next?
Do you
have the same problem?
Tuesday, January 2nd, 2018 AT 1:59 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,544 POSTS
It sounds like a temperature blend door actuator has let go. Here is a guide to help you see what you are in for when changing it and the diagrams below to show you how ti will be on your car
and
https://www.2carpros.com/articles/car-heater-not-working
Check out the diagrams (Below)
Please get back to us.
Cheers, Ken
Wednesday, January 3rd, 2018 AT 8:17 PM
WAYNO123
  • 5 POSTS
  • 3.3L
  • 6 CYL
  • 120,000 MILES
No heat when outside temperatures are really cold. When the engine warms up I do get heat if I really step on the gas. Sometimes when I let my foot off it goes back to cold air. I changed thermostat and coolant. No help.
Monday, November 2nd, 2020 AT 7:55 AM (Merged)
SATURNTECH9
  • 30,870 POSTS
The two small hoses going into the heater core at the firewall when the engine is at operating temp. Are they both getting too hot to hold?If one is but the other isn't the flow in the heater core is restricted. Do you know if coolant stop leak has ever been used in the radiator?
WAYNO123
  • 5 POSTS
Both hoses are hot. Stop leak never used. Thanks. Im leaning toward the water pump.
SATURNTECH9
  • 30,870 POSTS
Are both getting too hot to hold?The water pump is a Kong shot if the pump wasn't circulating enough coolant I would think you would be having overheating issues.
JOHNNY G.JR
  • 320 POSTS
Has cooling system been back flushed since new? Not drained and refilled.
WAYNO123
  • 5 POSTS
Not flushed. Only drained and refilled. Temp not going all the way up now. Only halfway. I thought that was due to the ice cold temps outside but not that its warmed up a little outside, engine temp not going up to normal. Ugh!
Thanks for your help
SATURNTECH9
  • 30,870 POSTS
Maybe you got a bad new thermostat
WAYNO123
  • 5 POSTS
It's happened before on another car. Thanks for all your help. Happy New Year.
JOHNNY G.JR
  • 320 POSTS
Thermostat has my vote also
SATURNTECH9
  • 30,870 POSTS
That's to check if a thermostat isn't opening sounds like the thermostat is allowing flow when it shouldn't. Like a bad seal or partially stuck open.
JOHNNY G.JR
  • 320 POSTS
Keep us posted here at 2carpros, one more thing is cooling fan cycling properly
WAYNO123
  • 5 POSTS
Yes! I got heat. Tons of heat. Faulty thermostat I got at AutoZone. Picked up a new Stant thermostat today.I need this old van to haul my gear for ice fishing. Got bait.I'll be on lake tomorrow. Thanks for everything.
SATURNTECH9
  • 30,870 POSTS
Glad to hear it I always get the start thermostat when I buy them. Let me know how the fishing goes tomorrow.
ESTHER
  • 14,900 MILES
Why would there be no heat? - Thanks for your help
  • 108,005 POSTS
It could be a couple things. First, with the engine hot and the heat on, feel both heater core hoses. Both should be hot. If only one is hot, flush the heater core. If both are hot, check the blend door. Chances are it is stuck.
SIGN BOY
Hi, I realize this is an old question, but I have a similar problem. What is the next step if both hoses for the heater core are cold? The hose from the radiator to the manifold is hot.
DRIVEINON
  • 6 CYL
As I was driving home my heater started blowing cold air and the temp gauge started climbing. There was a really bad smell
Monday, November 2nd, 2020 AT 7:56 AM (Merged)
CARADIODOC
  • 33,699 POSTS
Those are all indications of a leak in the cooling system. Have you looked for a leak?
DRIVEINON
I have not, I will in the morning
