Engine shuts off when idling or at a stop
NOVATTACK
  • 2006 PONTIAC GRAND PRIX
  • 3.8L
  • V6
  • 130,000 MILES
My car shut off while driving and would not start even after cooling down. Had no engine light and no codes. Replaced the crank sensor and did a relearn. Ran good for about a week. Now when the temperature is up it shuts off at idle in park or driving when you stop. No engine light. No engine codes. After it cools down starts right up. 12.5 volts at the battery when the car is off. 14.5 volts when running.
Friday, January 12th, 2018 AT 11:24 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,882 POSTS
The first thing we should do is run the codes here is a guide to help you.
and
Cheers, Ken
Saturday, January 13th, 2018 AT 8:34 PM
KOLPAX
  • 116,000 MILES
Say like when I floor it the car will stall right before it shifts gears and the motor shuts off. Now if I drive my car and just casual I guess you could say it has no problems shifts gears perfectly no miss doesn't run sluggish or anything.
Saturday, December 22nd, 2018 AT 1:28 PM (Merged)
  • 52,797 POSTS
There is a rev limiter on the motor rpm. It is around 4 to 4500 rpm. At that point, it will act like it shuts down. Does it actually turn off? You have to re start it?
KOLPAX
The motor shuts off I have to pull over place it back in park and restart the car. Thanks for taking the time to answer my question.
  • 52,797 POSTS
This may be a pcm issue. Have a shop look at this. It is not supposed to stall the motor, just limit the rpm range and return to normal operation.
KOLPAX
Well one other thing, but not sure if has much to do with this issue. I got the p2432 error code. Found out its the secondary air pump issue. My valve that connects to the catalytic converter was rusted shut so I removed it for the time being until I get a new one in there. My air pump motor works just fine it was just the valve being rusted shut that appears to gave me the code. So to keep the fumes returning in the engine bay I cut a can and used the bolt holes that was connected to the valve and bolted down the cut out I made to make a seal. I am wondering if not having the valve connected on the electronic side would cause this. I figured what I did covering the hole really made no difference from the valve being rusted shut and blocking the return line. I ordered a new valve already so will have that fixed, just curious if this would or could cause a stall.
KOLPAX
So I plugged the bad Secondary Air Check Valve back in just on the connector side and zip tied it so it doesn't move around. Now the car doesn't stall anymore. I just don't understand how this being plugged in would prevent a car from stalling.
CTAYLOR42O
  • 2001 PONTIAC GRAND PRIX
Our Pontiac has been having issues with cutting off while driving, all the lights are still on and working but engine dies and we lose power steering and the car sputters terribly when we try to restart. We were told it was the mass air flow sensor we bought the part yesterday and replaced it. It seemed to have worked for a while but after driving for a while it started doing the same things again. I also don't think it could be the alternator because all the lights still work and the battery holds charge. Please Help. Thank You!
FREEMBA
  • 1,152 POSTS
Please take your car to Autozone (or one of those auto parts stores) and have tem to read the computer codes. These codes will give an indication of which system is having trouble (kinda puts us in the right area for proper diagnosis). The auto parts store will do this for free. Write the code(s) down and post them here for more help.
Also, they will check the chargiing system for free as well (just to put that potential worry to rest).
I look forward to hearing from you with the results of the computer scan.
KEVINBOGAN
  • 2000 PONTIAC GRAND PRIX
  • 3.8L
  • 6 CYL
  • TURBO
I changed the ignition module all coil packs complete tune up changed egr valve car just dies when driving seems like when I gets hot it shuts off start right up when sitting for a few hrs no problem code p0650 pops up malfunction indicator Lamp is it a electrical issue that I can trace from the pcm or what car is getting good gas no problem
  • 108,170 POSTS
That code is really generic. I really don't feel it has anything to do with the running issue. It is simply related to the MIL light itself.
As far as the problem, when it stalls and you have to let it sit, have you checked to see if there is spark and fuel to the engine?
KEVINBOGAN
It's getting string spark I changed the fuel filter and working on pump but can't keep the lines to come off the plastic tab any idea would be very grateful
KEVINBOGAN
I just changed the pump and everything else I listed and still shutting off what else is there to it
  • 108,170 POSTS
Tell me this. When it shuts down, is the spark you are getting a hot blue snapping spark, or is it an orange or white color? I will assume you confirmed that the fuel pump pressure is within spec, correct? I need you to try something for me. When it warms up and then stalls and refuses to restart, see if it will start using starting fluid and run for a couple seconds.
OPTI621
  • PONTIAC GRAND PRIX
Ok, my grand prix started having trouble yesterday. It was a rainy day. The first problem I had was pulling out of a parking lot, I pulled into the road and the car died. Later I parked on a driveway that was slanted and the car wouldnt even try to turn over, I rolled it down the driveway then it started up right away. Then driving home on the highway it jerked forward a couple times died out. I pushed it onto a residential road and got it started but it would just idle out in the same fashion then eventually it wouldnt run at all. Sometimes it would start and idle but it would do the same thing, I describe it as if you were pushing the gas peddle forward slightly in a jerking motion while the car was running. I waited a half hour and tried, it started, so I tried to drive home again and a minute or two later it died out in the same way it did before. The car jerks forward a couple times and the gas stops working then the engine dies. I got it to a parking lot by pushing and left it for the night.
I thought it was just wiring problem or the rain but the next day it was dry and I went to check it out and tow it but it started and made it home without a problem. Later I test drove it and it died out again in the same way, jerked forward the same way a few times, and wouldnt restart at all.
So occasionally it starts but dies out, sometimes a few seconds or sometimes minutes later.
I had it towed today and a shop is planning on looking at it tomorrow Oct 19.
A friend said it was the fuel injectors (i found a bottle of fuel injector cleaner that goes in the gas tank from the previous owner too if that means anything), my dad says its the fuel pump, I think it could be those or the spark plugs or lines that go to them or drive belt but I really have no idea?
I dont want to go to the shop and have no idea whats wrong because I dont want to get ripped off paying to repair something thats not even wrong with the car. So whats wrong with my car? And how much should I expect to be paying(estimate) to have it repaired? I
MERLIN2021
  • 17,250 POSTS
Sounds more like a fuel delivery issue, if you mean wouldnt turn over to mean wouldnt start, if the motor wouldnt crank, sometihing else is going on. Any codes stored? Check engine light on?
OPTI621
Wouldnt start meaning it would crank and try to start but wont start up after it cuts out. No check engine light, dont know how to tell if codes are stored?
A smart friend says if the fuel pump isnt working then when I first start it the suction pulls enough fuel to run for a little but it cuts out when thats all sucked up cuz the fuel pump isn't doing it's job.
How much should I expect to pay(estimate) for fuel pump and install if that is the problem?
MERLIN2021
  • 17,250 POSTS
First thing to check is open the fuel door, temove the cap and have someone turn the key to on, you should hear the pump run for 2-3 seconds, if not check the fuse for it. If it doesn't run it won't pump.
MGILLDESIGN
  • 2003 PONTIAC GRAND PRIX
  • 3.8L
  • 6 CYL
  • 108,000 MILES
My car drives fine, but cuts off while driving (highway or streets). No check engine (just oil pressure and battery light). It usually starts right back up. Sometimes it will take several minutes, but starts back up.
All the mechanics/shops I take it to, say that it starts up for them and they can't get it to cut off, so they send me home.
Frustrated, I bought an OBD II scanner to record data while I'm driving.
I have the following data: (note: that I have had the following repairs already this year- alternator, fuel pump, power steering pump, spark plugs, crankshaft sensor, lock cylinder--key stuck, new battery, O2 sensor).
This is pretty much my last resort, as i've spent several thousand dollars on this car this year. And will be forced to get rid of it, otherwise.
The car begins to cut off around frame# 44
2003 Pontiac Grand Prix 1 = 3.8
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon ok
Oxygen Sens Htr ok
EGR System Mon ok
DTCs (Codes)
No Codes Found
Record Data
FRAME: 0 TM: 0.0
MIL STATUS Off
ABSLT TPS(%) 7.5
ENG SPEED(RPM) 1317
CALC LOAD(%) 10.2
MAF(LB/M) 2.44
MAP("HG) 18.9
COOLANT(°F) 199
IAT(°F) 95
IGN ADV(°) 37.0
ST FTRM1(%) -4.7
LT FTRM1(%) -2.3
VEH SPEED(MPH) 6
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.560
ST FTRM11(%) 16.4
O2S12(V) 0.665
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 1 TM: 1.7
MIL STATUS Off
ABSLT TPS(%) 12.6
ENG SPEED(RPM) 1973
CALC LOAD(%) 15.7
MAF(LB/M) 3.74
MAP("HG) 21.6
COOLANT(°F) 199
IAT(°F) 95
IGN ADV(°) 34.0
ST FTRM1(%) -0.8
LT FTRM1(%) 0.8
VEH SPEED(MPH) 14
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.730
ST FTRM11(%) -53.9
O2S12(V) 0.645
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 2 TM: 3.5
MIL STATUS Off
ABSLT TPS(%) 13.7
ENG SPEED(RPM) 2441
CALC LOAD(%) 18.4
MAF(LB/M) 4.45
MAP("HG) 19.8
COOLANT(°F) 199
IAT(°F) 95
IGN ADV(°) 36.5
ST FTRM1(%) -0.8
LT FTRM1(%) 0.8
VEH SPEED(MPH) 20
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.805
ST FTRM11(%) 21.9
O2S12(V) 0.650
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 3 TM: 5.4
MIL STATUS Off
ABSLT TPS(%) 14.1
ENG SPEED(RPM) 2186
CALC LOAD(%) 18.4
MAF(LB/M) 4.32
MAP("HG) 22.1
COOLANT(°F) 199
IAT(°F) 95
IGN ADV(°) 33.0
ST FTRM1(%) 3.9
LT FTRM1(%) 0.8
VEH SPEED(MPH) 25
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.660
ST FTRM11(%) 0.0
O2S12(V) 0.645
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 4 TM: 7.1
MIL STATUS Off
ABSLT TPS(%) 14.1
ENG SPEED(RPM) 2350
CALC LOAD(%) 18.4
MAF(LB/M) 4.24
MAP("HG) 21.0
COOLANT(°F) 199
IAT(°F) 95
IGN ADV(°) 33.5
ST FTRM1(%) -0.8
LT FTRM1(%) 0.8
VEH SPEED(MPH) 30
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.080
ST FTRM11(%) -82.0
O2S12(V) 0.645
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 5 TM: 8.9
MIL STATUS Off
ABSLT TPS(%) 12.9
ENG SPEED(RPM) 1875
CALC LOAD(%) 17.3
MAF(LB/M) 3.98
MAP("HG) 22.1
COOLANT(°F) 199
IAT(°F) 93
IGN ADV(°) 26.5
ST FTRM1(%) 3.9
LT FTRM1(%) 0.8
VEH SPEED(MPH) 34
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.200
ST FTRM11(%) 18.0
O2S12(V) 0.645
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 6 TM: 10.7
MIL STATUS Off
ABSLT TPS(%) 5.5
ENG SPEED(RPM) 1713
CALC LOAD(%) 7.1
MAF(LB/M) 1.50
MAP("HG) 10.3
COOLANT(°F) 199
IAT(°F) 93
IGN ADV(°) 22.0
ST FTRM1(%) 2.3
LT FTRM1(%) -2.3
VEH SPEED(MPH) 35
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.770
ST FTRM11(%) 21.9
O2S12(V) 0.645
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 7 TM: 12.5
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 1480
CALC LOAD(%) 3.9
MAF(LB/M) 0.89
MAP("HG) 8.0
COOLANT(°F) 199
IAT(°F) 93
IGN ADV(°) 16.0
ST FTRM1(%) 5.5
LT FTRM1(%) -1.6
VEH SPEED(MPH) 35
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.810
ST FTRM11(%) 27.3
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 8 TM: 14.3
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 1044
CALC LOAD(%) 2.7
MAF(LB/M) 0.69
MAP("HG) 8.3
COOLANT(°F) 199
IAT(°F) 95
IGN ADV(°) 18.5
ST FTRM1(%) -3.1
LT FTRM1(%) -1.6
VEH SPEED(MPH) 36
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.095
ST FTRM11(%) -87.5
O2S12(V) 0.635
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 9 TM: 16.1
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 907
CALC LOAD(%) 2.4
MAF(LB/M) 0.60
MAP("HG) 8.3
COOLANT(°F) 199
IAT(°F) 95
IGN ADV(°) 19.5
ST FTRM1(%) -1.6
LT FTRM1(%) -2.3
VEH SPEED(MPH) 37
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.460
ST FTRM11(%) -75.0
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 10 TM: 17.9
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 884
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 8.6
COOLANT(°F) 199
IAT(°F) 95
IGN ADV(°) 20.0
ST FTRM1(%) -3.1
LT FTRM1(%) -2.3
VEH SPEED(MPH) 37
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.095
ST FTRM11(%) -85.2
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 11 TM: 19.6
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 900
CALC LOAD(%) 2.4
MAF(LB/M) 0.59
MAP("HG) 8.6
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 20.0
ST FTRM1(%) 0.0
LT FTRM1(%) -2.3
VEH SPEED(MPH) 35
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.125
ST FTRM11(%) -80.5
O2S12(V) 0.630
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 12 TM: 21.4
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 859
CALC LOAD(%) 2.4
MAF(LB/M) 0.60
MAP("HG) 8.6
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 20.0
ST FTRM1(%) -0.8
LT FTRM1(%) -2.3
VEH SPEED(MPH) 34
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.530
ST FTRM11(%) -23.4
O2S12(V) 0.635
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 13 TM: 23.3
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 871
CALC LOAD(%) 2.4
MAF(LB/M) 0.60
MAP("HG) 8.9
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 20.0
ST FTRM1(%) 1.6
LT FTRM1(%) -2.3
VEH SPEED(MPH) 26
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.095
ST FTRM11(%) -82.8
O2S12(V) 0.635
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 14 TM: 25.0
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 808
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 20.5
ST FTRM1(%) -0.8
LT FTRM1(%) -2.3
VEH SPEED(MPH) 16
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.675
ST FTRM11(%) -0.8
O2S12(V) 0.635
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 15 TM: 26.8
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 765
CALC LOAD(%) 2.4
MAF(LB/M) 0.59
MAP("HG) 10.0
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 18.0
ST FTRM1(%) -0.8
LT FTRM1(%) -3.1
VEH SPEED(MPH) 11
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.045
ST FTRM11(%) -92.2
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 16 TM: 28.6
MIL STATUS Off
ABSLT TPS(%) 12.6
ENG SPEED(RPM) 2219
CALC LOAD(%) 16.9
MAF(LB/M) 3.97
MAP("HG) 20.1
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 35.5
ST FTRM1(%) -4.7
LT FTRM1(%) 0.8
VEH SPEED(MPH) 17
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.645
ST FTRM11(%) -23.4
O2S12(V) 0.630
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 17 TM: 30.4
MIL STATUS Off
ABSLT TPS(%) 14.1
ENG SPEED(RPM) 2253
CALC LOAD(%) 19.2
MAF(LB/M) 4.29
MAP("HG) 23.3
COOLANT(°F) 203
IAT(°F) 97
IGN ADV(°) 32.0
ST FTRM1(%) 0.0
LT FTRM1(%) 0.8
VEH SPEED(MPH) 23
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.730
ST FTRM11(%) 1.6
O2S12(V) 0.630
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 18 TM: 32.2
MIL STATUS Off
ABSLT TPS(%) 14.9
ENG SPEED(RPM) 2289
CALC LOAD(%) 19.2
MAF(LB/M) 4.51
MAP("HG) 21.9
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 34.5
ST FTRM1(%) 3.9
LT FTRM1(%) 1.6
VEH SPEED(MPH) 28
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.775
ST FTRM11(%) 20.3
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 19 TM: 34.0
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 1967
CALC LOAD(%) 16.1
MAF(LB/M) 3.76
MAP("HG) 20.7
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 28.5
ST FTRM1(%) -0.8
LT FTRM1(%) 1.6
VEH SPEED(MPH) 32
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.725
ST FTRM11(%) -69.5
O2S12(V) 0.655
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 20 TM: 35.8
MIL STATUS Off
ABSLT TPS(%) 8.2
ENG SPEED(RPM) 1722
CALC LOAD(%) 10.2
MAF(LB/M) 1.93
MAP("HG) 13.0
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 21.0
ST FTRM1(%) -0.8
LT FTRM1(%) -2.3
VEH SPEED(MPH) 35
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.555
ST FTRM11(%) 18.8
O2S12(V) 0.645
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 21 TM: 37.6
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 1479
CALC LOAD(%) 3.9
MAF(LB/M) 0.91
MAP("HG) 8.0
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 16.0
ST FTRM1(%) 2.3
LT FTRM1(%) -1.6
VEH SPEED(MPH) 34
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.760
ST FTRM11(%) 18.8
O2S12(V) 0.645
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 22 TM: 39.4
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 1047
CALC LOAD(%) 2.7
MAF(LB/M) 0.70
MAP("HG) 8.6
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 23.5
ST FTRM1(%) -3.9
LT FTRM1(%) -3.9
VEH SPEED(MPH) 34
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.075
ST FTRM11(%) -90.6
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 23 TM: 41.2
MIL STATUS Off
ABSLT TPS(%) 12.6
ENG SPEED(RPM) 2126
CALC LOAD(%) 16.1
MAF(LB/M) 3.62
MAP("HG) 20.4
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 26.0
ST FTRM1(%) 4.7
LT FTRM1(%) -1.6
VEH SPEED(MPH) 35
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.840
ST FTRM11(%) 29.7
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 24 TM: 43.0
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 1534
CALC LOAD(%) 4.3
MAF(LB/M) 0.99
MAP("HG) 8.3
COOLANT(°F) 199
IAT(°F) 95
IGN ADV(°) 17.0
ST FTRM1(%) 0.0
LT FTRM1(%) -1.6
VEH SPEED(MPH) 34
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.745
ST FTRM11(%) 18.0
O2S12(V) 0.635
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 25 TM: 44.8
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 862
CALC LOAD(%) 2.4
MAF(LB/M) 0.62
MAP("HG) 9.2
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 20.5
ST FTRM1(%) -5.5
LT FTRM1(%) -2.3
VEH SPEED(MPH) 32
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.065
ST FTRM11(%) -90.6
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 26 TM: 46.6
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 826
CALC LOAD(%) 2.4
MAF(LB/M) 0.60
MAP("HG) 9.2
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 20.0
ST FTRM1(%) -3.9
LT FTRM1(%) -2.3
VEH SPEED(MPH) 29
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.080
ST FTRM11(%) -85.9
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 27 TM: 48.4
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 838
CALC LOAD(%) 2.4
MAF(LB/M) 0.59
MAP("HG) 9.2
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 20.5
ST FTRM1(%) -1.6
LT FTRM1(%) -2.3
VEH SPEED(MPH) 24
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.085
ST FTRM11(%) -89.1
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 28 TM: 50.2
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 824
CALC LOAD(%) 2.4
MAF(LB/M) 0.60
MAP("HG) 9.2
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 21.5
ST FTRM1(%) 0.8
LT FTRM1(%) -2.3
VEH SPEED(MPH) 14
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.620
ST FTRM11(%) 0.8
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 29 TM: 52.0
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 758
CALC LOAD(%) 2.4
MAF(LB/M) 0.62
MAP("HG) 10.0
COOLANT(°F) 201
IAT(°F) 95
IGN ADV(°) 21.5
ST FTRM1(%) 0.8
LT FTRM1(%) -2.3
VEH SPEED(MPH) 7
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.065
ST FTRM11(%) -89.8
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 30 TM: 53.7
MIL STATUS Off
ABSLT TPS(%) 3.1
ENG SPEED(RPM) 1174
CALC LOAD(%) 4.3
MAF(LB/M) 1.02
MAP("HG) 10.6
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 32.0
ST FTRM1(%) 1.6
LT FTRM1(%) -3.9
VEH SPEED(MPH) 7
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.645
ST FTRM11(%) -58.6
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 31 TM: 55.5
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 1030
CALC LOAD(%) 3.1
MAF(LB/M) 0.78
MAP("HG) 9.2
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 20.5
ST FTRM1(%) 3.1
LT FTRM1(%) -2.3
VEH SPEED(MPH) 6
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.140
ST FTRM11(%) -77.3
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 32 TM: 57.3
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 715
CALC LOAD(%) 2.7
MAF(LB/M) 0.65
MAP("HG) 10.3
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 22.5
ST FTRM1(%) 0.0
LT FTRM1(%) 1.6
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.695
ST FTRM11(%) -3.1
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 33 TM: 59.1
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 729
CALC LOAD(%) 2.7
MAF(LB/M) 0.65
MAP("HG) 10.9
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 22.5
ST FTRM1(%) -0.8
LT FTRM1(%) 0.8
VEH SPEED(MPH) 1
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.135
ST FTRM11(%) -92.2
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 34 TM: 60.9
MIL STATUS Off
ABSLT TPS(%) 4.7
ENG SPEED(RPM) 1280
CALC LOAD(%) 6.7
MAF(LB/M) 1.58
MAP("HG) 14.2
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 21.5
ST FTRM1(%) 1.6
LT FTRM1(%) -2.3
VEH SPEED(MPH) 6
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.795
ST FTRM11(%) 27.3
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 35 TM: 62.7
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 994
CALC LOAD(%) 3.5
MAF(LB/M) 0.78
MAP("HG) 10.3
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 21.0
ST FTRM1(%) 0.0
LT FTRM1(%) -2.3
VEH SPEED(MPH) 4
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.705
ST FTRM11(%) 19.5
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 36 TM: 64.5
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 710
CALC LOAD(%) 2.7
MAF(LB/M) 0.64
MAP("HG) 10.6
COOLANT(°F) 201
IAT(°F) 97
IGN ADV(°) 24.0
ST FTRM1(%) 0.8
LT FTRM1(%) 1.6
VEH SPEED(MPH) 1
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.695
ST FTRM11(%) -3.1
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 37 TM: 66.3
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 743
CALC LOAD(%) 2.4
MAF(LB/M) 0.59
MAP("HG) 10.0
COOLANT(°F) 203
IAT(°F) 97
IGN ADV(°) 24.0
ST FTRM1(%) -1.6
LT FTRM1(%) 1.6
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.725
ST FTRM11(%) 24.2
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 38 TM: 68.1
MIL STATUS Off
ABSLT TPS(%) 6.7
ENG SPEED(RPM) 927
CALC LOAD(%) 7.5
MAF(LB/M) 1.71
MAP("HG) 16.8
COOLANT(°F) 203
IAT(°F) 97
IGN ADV(°) 35.0
ST FTRM1(%) -7.0
LT FTRM1(%) -3.9
VEH SPEED(MPH) 3
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.065
ST FTRM11(%) -86.7
O2S12(V) 0.625
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 39 TM: 69.9
MIL STATUS Off
ABSLT TPS(%) 9.4
ENG SPEED(RPM) 1766
CALC LOAD(%) 12.9
MAF(LB/M) 2.99
MAP("HG) 19.5
COOLANT(°F) 203
IAT(°F) 97
IGN ADV(°) 36.5
ST FTRM1(%) -7.8
LT FTRM1(%) 1.6
VEH SPEED(MPH) 11
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.115
ST FTRM11(%) -74.2
O2S12(V) 0.640
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 40 TM: 71.7
MIL STATUS Off
ABSLT TPS(%) 14.9
ENG SPEED(RPM) 2350
CALC LOAD(%) 20.0
MAF(LB/M) 4.79
MAP("HG) 21.9
COOLANT(°F) 203
IAT(°F) 95
IGN ADV(°) 31.0
ST FTRM1(%) 0.0
LT FTRM1(%) 1.6
VEH SPEED(MPH) 19
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.130
ST FTRM11(%) -0.8
O2S12(V) 0.655
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 41 TM: 73.5
MIL STATUS Off
ABSLT TPS(%) 16.5
ENG SPEED(RPM) 2879
CALC LOAD(%) 23.5
MAF(LB/M) 5.18
MAP("HG) 22.4
COOLANT(°F) 203
IAT(°F) 95
IGN ADV(°) 30.5
ST FTRM1(%) -3.9
LT FTRM1(%) 1.6
VEH SPEED(MPH) 25
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.100
ST FTRM11(%) -2.3
O2S12(V) 0.605
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 42 TM: 75.3
MIL STATUS Off
ABSLT TPS(%) 15.7
ENG SPEED(RPM) 2380
CALC LOAD(%) 21.2
MAF(LB/M) 4.89
MAP("HG) 23.3
COOLANT(°F) 205
IAT(°F) 95
IGN ADV(°) 33.0
ST FTRM1(%) 0.0
LT FTRM1(%) 1.6
VEH SPEED(MPH) 29
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.815
ST FTRM11(%) 27.3
O2S12(V) 0.595
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 43 TM: 77.1
MIL STATUS Off
ABSLT TPS(%) 12.6
ENG SPEED(RPM) 1941
CALC LOAD(%) 16.9
MAF(LB/M) 3.88
MAP("HG) 21.9
COOLANT(°F) 205
IAT(°F) 95
IGN ADV(°) 29.0
ST FTRM1(%) 0.0
LT FTRM1(%) 1.6
VEH SPEED(MPH) 32
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.620
ST FTRM11(%) -66.4
O2S12(V) 0.620
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 44 TM: 78.9
MIL STATUS Off
ABSLT TPS(%) 10.6
ENG SPEED(RPM) 1674
CALC LOAD(%) 14.1
MAF(LB/M) 3.07
MAP("HG) 20.1
COOLANT(°F) 205
IAT(°F) 95
IGN ADV(°) -2.0
ST FTRM1(%) 0.0
LT FTRM1(%) 1.6
VEH SPEED(MPH) 32
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.035
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 45 TM: 80.7
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 133
CALC LOAD(%) 3.5
MAF(LB/M) 0.84
MAP("HG) 29.2
COOLANT(°F) 205
IAT(°F) 95
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 32
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.015
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 46 TM: 82.5
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 3.5
MAF(LB/M) 0.18
MAP("HG) 29.2
COOLANT(°F) 207
IAT(°F) 95
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 27
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.020
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 47 TM: 84.3
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 3.5
MAF(LB/M) 0.18
MAP("HG) 29.2
COOLANT(°F) 207
IAT(°F) 95
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 24
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.015
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 48 TM: 86.1
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 3.5
MAF(LB/M) 0.18
MAP("HG) 29.2
COOLANT(°F) 207
IAT(°F) 95
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 19
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.015
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 49 TM: 88.0
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 3.5
MAF(LB/M) 0.18
MAP("HG) 29.2
COOLANT(°F) 207
IAT(°F) 97
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 12
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.015
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 50 TM: 89.7
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 3.5
MAF(LB/M) 0.18
MAP("HG) 29.2
COOLANT(°F) 207
IAT(°F) 97
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 4
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.015
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 51 TM: 91.5
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 3.5
MAF(LB/M) 0.18
MAP("HG) 29.2
COOLANT(°F) 207
IAT(°F) 97
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.015
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 52 TM: 93.3
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 3.5
MAF(LB/M) 0.18
MAP("HG) 29.2
COOLANT(°F) 207
IAT(°F) 97
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.015
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 53 TM: 95.1
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 3.5
MAF(LB/M) 0.18
MAP("HG) 29.2
COOLANT(°F) 207
IAT(°F) 99
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.020
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 54 TM: 96.9
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 3.5
MAF(LB/M) 0.18
MAP("HG) 29.2
COOLANT(°F) 207
IAT(°F) 99
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.020
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 55 TM: 98.7
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 0.0
MAF(LB/M) 0.54
MAP("HG) 29.2
COOLANT(°F) 207
IAT(°F) 99
IGN ADV(°) 0.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.000
ST FTRM11(%) -100.0
O2S12(V) 0.020
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 56 TM: 100.5
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 0
CALC LOAD(%) 0.0
MAF(LB/M) 0.54
MAP("HG) 28.3
COOLANT(°F) 207
IAT(°F) 100
IGN ADV(°) 10.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.005
ST FTRM11(%) -99.2
O2S12(V) 0.025
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 57 TM: 102.4
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 788
CALC LOAD(%) 2.4
MAF(LB/M) 0.59
MAP("HG) 10.6
COOLANT(°F) 207
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.035
ST FTRM11(%) -93.8
O2S12(V) 0.035
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 58 TM: 104.2
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 776
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.4
COOLANT(°F) 207
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.130
ST FTRM11(%) -79.7
O2S12(V) 0.070
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 59 TM: 106.1
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 746
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.4
COOLANT(°F) 208
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.755
ST FTRM11(%) 8.6
O2S12(V) 0.080
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 60 TM: 107.8
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 780
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.4
COOLANT(°F) 208
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.765
ST FTRM11(%) 22.7
O2S12(V) 0.085
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 61 TM: 109.6
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 784
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 208
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.790
ST FTRM11(%) 21.9
O2S12(V) 0.090
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 62 TM: 111.4
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 783
CALC LOAD(%) 2.4
MAF(LB/M) 0.59
MAP("HG) 9.2
COOLANT(°F) 210
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN1
FUEL SYS 2 OPEN1
O2S11(V) 0.740
ST FTRM11(%) 17.2
O2S12(V) 0.095
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 63 TM: 113.2
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 730
CALC LOAD(%) 2.4
MAF(LB/M) 0.59
MAP("HG) 9.4
COOLANT(°F) 212
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.115
ST FTRM11(%) -82.0
O2S12(V) 0.100
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 64 TM: 115.0
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 790
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 212
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 1.6
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.195
ST FTRM11(%) -59.4
O2S12(V) 0.105
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 65 TM: 116.8
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 774
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 212
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 1.6
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.570
ST FTRM11(%) -11.7
O2S12(V) 0.120
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 66 TM: 118.6
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 790
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 212
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 1.6
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.620
ST FTRM11(%) -7.8
O2S12(V) 0.125
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 67 TM: 120.4
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 770
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 210
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 1.6
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.590
ST FTRM11(%) 2.3
O2S12(V) 0.130
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 68 TM: 122.2
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 766
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 210
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 2.3
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.255
ST FTRM11(%) -72.7
O2S12(V) 0.140
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 69 TM: 124.0
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 793
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 210
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 2.3
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.150
ST FTRM11(%) -54.7
O2S12(V) 0.145
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 70 TM: 125.8
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 779
CALC LOAD(%) 2.4
MAF(LB/M) 0.59
MAP("HG) 9.2
COOLANT(°F) 210
IAT(°F) 100
IGN ADV(°) 19.5
ST FTRM1(%) 3.1
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.700
ST FTRM11(%) 6.3
O2S12(V) 0.150
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 71 TM: 127.6
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 791
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 210
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 1.6
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.525
ST FTRM11(%) -27.3
O2S12(V) 0.155
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 72 TM: 129.4
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 815
CALC LOAD(%) 2.4
MAF(LB/M) 0.59
MAP("HG) 9.2
COOLANT(°F) 210
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 2.3
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.660
ST FTRM11(%) -1.6
O2S12(V) 0.160
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 73 TM: 131.2
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 769
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 210
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 2.3
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.605
ST FTRM11(%) -7.0
O2S12(V) 0.160
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 74 TM: 133.0
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 795
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 212
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 1.6
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.675
ST FTRM11(%) 4.7
O2S12(V) 0.160
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 75 TM: 134.8
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 769
CALC LOAD(%) 2.4
MAF(LB/M) 0.57
MAP("HG) 9.2
COOLANT(°F) 212
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 0.0
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.505
ST FTRM11(%) -11.7
O2S12(V) 0.165
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 76 TM: 136.6
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 778
CALC LOAD(%) 2.4
MAF(LB/M) 0.56
MAP("HG) 9.2
COOLANT(°F) 212
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 2.3
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.685
ST FTRM11(%) 2.3
O2S12(V) 0.165
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 77 TM: 138.4
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 755
CALC LOAD(%) 2.4
MAF(LB/M) 0.57
MAP("HG) 9.4
COOLANT(°F) 212
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 0.8
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.655
ST FTRM11(%) -13.3
O2S12(V) 0.165
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 78 TM: 140.2
MIL STATUS Off
ABSLT TPS(%) 0.0
ENG SPEED(RPM) 820
CALC LOAD(%) 2.4
MAF(LB/M) 0.60
MAP("HG) 9.2
COOLANT(°F) 212
IAT(°F) 100
IGN ADV(°) 19.5
ST FTRM1(%) 3.9
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.715
ST FTRM11(%) 7.8
O2S12(V) 0.165
MIL DIST(mi) 0
OBD2 STAT CA/US
FRAME: 79 TM: 142.0
MIL STATUS Off
ABSLT TPS(%) 0.4
ENG SPEED(RPM) 791
CALC LOAD(%) 2.4
MAF(LB/M) 0.58
MAP("HG) 9.2
COOLANT(°F) 212
IAT(°F) 100
IGN ADV(°) 20.0
ST FTRM1(%) 2.3
LT FTRM1(%) -3.1
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.610
ST FTRM11(%) -3.1
O2S12(V) 0.170
MIL DIST(mi) 0
OBD2 STAT CA/US
Thank you,
Myron Gillespie
HMAC300
  • 48,601 POSTS
Check fuel pressure with a gauge it's probably lowand clean tthrottle plate on both sides an iac hole with choke cleaner vin K 53-39 psi minimum vin1 48-54 psi if any lower it's apump problem
