Blower fan not working?
MLLFG
  • 2005 HONDA ACCORD
  • 4 CYL
2005 Honda Accord heating and ac fan not working how do I repair? 4 cylinder coup. I checked all the fuses and they were good?What to do next?
Saturday, December 4th, 2010 AT 9:49 PM
KHLOW2008
  • 41,815 POSTS
If fan does not work in all speeds, it could be a bad motor. Heater fan motor is located under the glove box. Give it some banging to test if the motor starts working. If yes, the carbon is running out and motor has to be replaced.
This guide can help test.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Unplug the wire and use a test lamp to check for presence of battery voltage with ignition switch turned on. One of the wire should have battery voltage.
Sunday, December 5th, 2010 AT 4:23 AM
PARKER MCKINLEY
  • 2004 HONDA ACCORD
  • 4 CYL
  • FWD
  • 73,000 MILES
This summer, the blower fan in my 2004 Accord would work sometimes and not work others. It was diagnosed by a mechanic as a bad blower fan so I ordered a new one and installed it. The problem continued. For about the last month, the fan will not turn on at all, not even occasionally. It will not work for AC or Heat. When I start the car, the first time I try the switch, I can hear something try to engage and the fan acts like it wants to start, and then it won't go. After that initial attempt, when I turn the switch off and then on again, there is no response at all unless I turn the car off and then restart the engine.
Tuesday, December 1st, 2020 AT 12:58 PM (Merged)
PROMECHANIC
  • 536 POSTS
Since the fan was replaced you can rule that out. Assuming that it is a good part. The other possibilities are the switch that turns the fan on or the blower motor resistor.
PARKER MCKINLEY
Would the resistor work sometimes and not others as it was going bad? Any ideas on how hard the switch would be to replace?
PROMECHANIC
  • 536 POSTS
It is not as likely that the resistor would work sometimes and not others, but it is possible. The switch should not be too hard to replace depending on how good you are with mechanical repairs. It involves removing the bezel around the center dash, then removing the switch.
You could also have a wiring problem that is causing this too.
HAPPENING88
  • 8 POSTS
  • 2004 HONDA ACCORD
  • 6 CYL
All of a sudden the ac stopped working. The fan does nt work. Also heater, defrost everything does not. I cant feel any air coming out. The mechanic checked the fuses. They were fine. He said blower motor might be bad. So I bought that and replaced it myself. The fan still not working. I dont know whats wrong with this. I would really appreciate your help. Thank you.
HMAC300
  • 48,601 POSTS
Check blower relay item 1 in pic. If not that have it scanned for codes as it may be the heater control
HAPPENING88
  • 8 POSTS
The relay is fine and no codes. What else could be wrong? Do you think it could be blower motor resistor? The blower does not work regardless of the speed.
HMAC300
  • 48,601 POSTS
Only a pro can scan for codes for heater not auto parts or any hand held device. It can be the switch a fuse not known that operates it, etc. If the resistor is shot normally the blower will still work on high.
HMAC300
  • 48,601 POSTS
Here is an update on the heater control but I don't think that is your problem. Also check the pgm/main relay 1 under dash as that supplies power to blower relay
JILL DRYSDALE
  • 2003 HONDA ACCORD
Heater problem
2003 Honda Accord 71,000 miles
my blower for the AC and heater stopped working. I feel the heather working but the blower is not working. Is it just a fuse? I checked all the fuses in the car but the ones under the hood are not accessable.
THIS IS MIKE
  • 686 POSTS
All the fuses should be accessible and checked first. It could also be the blower motor or the switch. Check for power at the switch and the motor.
RDCN214
Had this also happen to me on my 03 Accord,
Under the passenger side dash you will find the blower motor and also part of the heating/ac unit. On the firewall side under the dash you will see a transistor with a plug and two screws attaching it. When you take it out it will look like a heat sink, that is the transistor that controls the fan speed. You can also test the blower motor before buying the transistor. To test the blower motor, disconnect the plug and connect positive and negative to the contact. Careful not to cause any sparks.
I was lucky to pick one up at the junk yard, but if not then here the part number from Honda
79330-SDA-A01 TRANSISTOR, POWER No Color
About 45-65 dollars.
Hope this helps
MUGD
  • 2002 HONDA ACCORD
  • 4 CYL
  • 68,000 MILES
This is the third time I am having this problem. Drivers side two blower blows hot air evenwhen a/c is on, but right two blowers r working very well. There is a clciking noise coming from dash board also.I had taken my car to honda dealer for reapairs, they said there was a leakage. But this is thied time in 8 months. Looks like they don't know whats the problem.
KHLOW2008
  • 41,815 POSTS
Hi mugd,
Something seems to be sticking by the ticking noise. Try turning the heater to max and the slowly turning back to AC max cold.
Tuesday, December 1st, 2020 AT 12:59 PM (Merged)
ROSEROD12
  • 2002 HONDA ACCORD
  • 125,023 MILES
Blower fan not working? No noise or other problem except all 3 went out at once. No lights are blinking, no over heating or another problem.
FIXITMR
  • 9,990 POSTS
Checked all fuses?
ROSEROD12
2003 Honda Accord (sorry), Yes, replaced all fuses with no results, car is driving fine except no air, raditator fan or auxillary fan working.
FIXITMR
  • 9,990 POSTS
When you say air, do you mean blower air inside car? Or AC not turning on?
