Mechanics
CAN'T GET 'BANK 1 TOO LEAN' CODE TO GO AWAY
2001 Toyota Corolla • 176,000 miles
The code on my car read p0171, bank 1 too lean. I changed the oxygen sensor, the mass air flow sensor is good, and there are no vacuum leaks. What else could it possibly be? I can't get the code to go away. It keeps popping up after I look for a problem and fix a problem and clear the code it keeps coming back. I don't know anything about cars and the people that are helping me can't figure it out either. I have a 2001 Toyota corolla ce sedan.
Jakesmommy12
August 27, 2013.
Have the valve clearances checked and adjusted if necessary.
Have the fuel pressure tested and check the fuel filter condition, replace if necessary.
KHLow2008
Aug 28, 2013.
AD
