Mechanics
CAM PULLEY AND TIMING BELT
1991 Honda Accord • 167,000 miles
I have a 91 Honda Accord. I couldn't set the timing because the belt had slipped a tooth on the cam pulley. I slipped the belt off the cam pulley with my fingers to turn the cam pulley one tooth but can't get the belt back on. I don't know a whole lot about cars. How can I put the belt back on the cam pulley?
MyCuteCar
May 8, 2013.
You ill have to remove the harmonic balance and all the belts and timing covers and release the tensioner, now the belt has been removed the tensioner may be stopping you from fitting the belt, and if it has slipped, you should replace the belt and make sure that there is no valve damage.
Mhpautos
May 9, 2013.
I already removed the belts, harmonic balancer and both covers. Now I just need to loosen the tensioner to put the belt back on the cam sprocket. How do I loosen the tensioner? Do I loosen the center bolt on the tensioner? If yes, wich way do I loosen it, counterclockwise or clockwise? I try both ways but it's hard either way. I don't want to use an extension and then go the wrong way.
MyCuteCar
May 14, 2013.
What is the engine code? There are a few variant for this model and year.
AD
Mhpautos
May 16, 2013.
Engine code is F22A1. I already know it loosens just like a normal bolt. To take it off I might have to heat it up with a torch because it's on there tight. Now my question is, to get the timing belt loose can I just push down on the tensioner without removing the nut on the front and the other belt and other tensioner or do I have to take off the nut, belt and other tensioner to loosen up the timing belt? All I want to do is put the timing belt back on the sprocket.
MyCuteCar
May 16, 2013.
Ed.
Mhpautos
May 27, 2013.
AD
