2006 Cadillac SRX
Engine Mechanical problem
2006 Cadillac SRX 6 cyl All Wheel Drive Automatic 60000 miles
My car uses about 2 qts of oil every 1,000 miles or so.
Engine seems to run OK but, is this normal.
Dealer cannot find anything wrong.
My lease is up in a few months, not sure whether I should risk purchasing car at end of lease.
September 15, 2009.
Acceptable oil consumption is 1 quart in 2000 miles. Has the consumption been accurately determined, or is this approximate? It can also be dependant upon individual driving habits. I will refer you to bulletins on consumption guidelines, and excessive consumption.
#01-06-01-011F: Information on Engine Oil Consumption Guidelines - (Jan 13, 2009)
Subject: Information on Engine Oil Consumption Guidelines
Models: 2009 and Prior GM Passenger Cars and Gasoline-Powered Light Duty Trucks Under 8500 LB GVW (Including Saturn)
2009 and Prior HUMMER H2, H3
2009 and Prior Saab 9-7X
This bulletin is being revised to update the warranty information on vehicles and add model years. Please discard Corporate Bulletin Number 01-06-01-011E (Section 06 -- Engine/Propulsion System).
All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the power stroke, part of this oil layer is consumed in the combustion process. As a result, varying rates of oil consumption are accepted as normal in all engines.
Oil Consumption
The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi).
Important: This rate only applies to personal use vehicles, under warranty, that are driven in a non-aggressive manner and maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or driven at legal speeds in an unloaded (for trucks) condition.
Important: This rate does not apply to vehicles that are driven in an aggressive manner, at high RPM, high speeds, or in a loaded condition (for trucks). Oil consumption for vehicles driven under these conditions will be more.
Many factors can affect a customer's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption.
Gasket and External Leaks
Inspect the oil pan and engine covers for leakage due to over-tightened, damaged, or out of place gaskets. Inspect oil lines and fittings for signs of leakage.
Improper Reading of the Oil Level Indicator (Dipstick)
Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked.
Notice: Operating your vehicle with an oil level that is below the minimum level indicated on the engine oil dipstick can result in severe engine damage. Repairs resulting from operating an engine with insufficient oil are not covered under the terms of the New Vehicle Warranty.
Important: Refer to Owner Manual in SI for checking and adding engine oil.
Not Waiting Long Enough After Running Engine to Check Oil Level
Some engines require more time than others for the oil to drain back into the crankcase. To assure a sufficient amount of oil has drained back to the crankcase, and an accurate reading can be obtained, the vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked.
Important: This does not apply to 2006-2009 Corvette Z06 equipped with the 7.0L LS7 and the 2009 Corvette ZR-1 with the 6.2L LS9 engines (dry sump). Follow the instructions in the Owner Manual for checking the oil in this application.
Improper Oil Fill After an Oil Change
Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner Manual or Service Manual for information on recommended oil quantity, viscosity, and quality.
Aggressive Driving, High Speed or High RPM Driving
Aggressive driving and/or continuous driving at high speeds/high RPMs will increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected.
A higher rate of oil consumption is normal for vehicles equipped with manual transmissions that are driven aggressively. By " aggressive, " we mean operation at high RPM (3,000 RPM to redline), with frequent use of engine braking (using the engine to slow the vehicle). Vehicles that are driven aggressively may consume engine oil at a rate of up to 0.946 L (1 quart) every 805 km (500 mi). This is normal for a vehicle that is driven aggressively. No repair is necessary. This characteristic does, however, require the owner to check the engine oil level at sufficiently frequent intervals, especially when driving aggressively, to assure the oil level remains within the recommended operating range. As the Owner's Manual recommends, you should check the oil level every time you get fuel.
Towing or Heavy Usage
Towing a trailer will increase oil consumption and may cause oil consumption to fall below the normal accepted rate referenced in this bulletin for an unloaded vehicle in a personal use application. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption.
Crankcase Ventilation System
Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use.
Oil Dilution (Fuel and Water)
On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, unburned fuel and condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture and fuel, may give the customer the impression of excessive oil consumption.
Engine Temperature
If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order.
Engine Wear
Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption.
Measurement of Oil Consumption
Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).
Verify that the engine has no external leaks. Repair as necessary.
Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual).
Park the vehicle on a level surface.
Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that the oil has had time to drain back into the crankcase.
Verify that the oil level is at, but not above, the full mark on the dipstick, and that the proper viscosity and quality oil are being used as recommended in the Owner's Manual.
Record the vehicle mileage, date, and exact oil level on the form included in this bulletin.
Ask the customer to verify the oil level, each time the vehicle is fueled, following steps 1-6 and return the vehicle to the dealership if the oil level is found at or below the add mark, 0.946 liter (1 qt) low. If the oil level remains above the add mark, the customer should continue to operate the vehicle and verify the engine oil level until 3200 km (2000 mi) has accumulated before returning to the dealership for a final evaluation.
If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 3200 km (2000 mi), follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 3200 km (2000 mi), explain to the customer that their engine meets the guidelines for oil consumption.
#PIP4439: HFV6 Oil Consumption - keywords 2.8 3.6 rings seal smoke valve - (Jul 23, 2008)
Subject: HFV6 Oil Consumption
Models: 2004-2007 Buick Rendezvous,
2005-2008 Buick Lacrosse, Allure
2008 Buick Enclave
2004-2008 Cadillac CTS, STS, SRX
2008 Chevrolet Malibu, Equinox
2008 GMC Acadia
2007-2008 Pontiac G6
2008 Pontiac G8, Torrent
2007-2008 Saturn Aura, Outlook
2008 Saturn Vue
with LP1 2.8L, LY7 3.6L, or LLT 3.6L V6 engine
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern: Some customers may comment of excess engine oil consumption.
Recommendation/Instructions: Verify the oil consumption concern following bulletin 01-06-01-011D. In addition, check the engine air filter and replace the air filter element as necessary. Care must be taken to ensure that the air filter and air filter box are reassembled correctly so that the filter and air box seal and prevent foreign particles from bypassing the filter. Check for signs of foreign particles bypassing the filter and getting into the engine, such as dust or dirt in the air intake duct or on the throttle body. If dust or dirt is found, look for the source of the leak, such as incorrectly assembled air filter/air filter box, loose clamps or incorrectly assembled joints at the air duct, leaking sensor gaskets, damaged duct parts, etc. And correct as necessary.
If oil consumption is in excess of the guidelines in bulletin 01-06-01-011D, replace the piston rings and valve seals.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a " do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
Sep 15, 2009.
