2003 Cadillac SLS Repair Question
Topics covered: Abs, Brakes, Brake lights.
Asked on October 25, 2008
2003 Cadillac SLS ABS,Brake,Traction control warning light
Electrical problem
2003 Cadillac SLS V8 Front Wheel Drive Automatic 87000 miles
The ABS,brake and Traction control warning lights come on. Then the temp control, front and rear, will not work, the seat heaters will not work abnd the car does release the E brake when shifted out of park. This is intermittent.The dealer replaced the ABS modul, no help. They removed it. This all started after I replaced the rear brakes. I can not make the liights come on or go off. When the ABS and brake lights go out, everything will work. I took the rear brakes off and replaced them, about 3 months ago, and the darned car did not mess up for 3 months. Now it has started again. Is there a sensor I may have mesed up when changing brakes? I also have removed an cleaned the grounding lug on both the drivers' and passenger door post. Do you have any miracle cures? I do not mind apying for help. AS this is the first time I have n=been on this site, I would like to see the answer prior to my paying.
