Mechanics
MUULTIPLE ERRORS AFTER REPLACING BRAKE PA
1999 Cadillac SLS
Computer problem
1999 Cadillac SLS V8 Two Wheel Drive Automatic 194000 miles
While replacing the brake pads I jacked the car up a bit extra high and set a cinder block under the frame, and I replaced all but one of the sensors back into their slots (one was broken and missing). However when I got done the dash still told me to replace my brake pads. Additionally it said to service my stabillity system, had the ABS light on and the traction control light was on and the button on the console would not take it off. HELP!
JamesEverham1@hotmail.com
February 1, 2010.
So the sensor that was broken and missing is still broken and missing? That is the open circuit that is triggering the change pads warning. If you press info up, and on/off, you will enter diagnosticafter a brief segment check. When it says ALL? Press on/off, and when it says ALL CODES? Press on/off again. Record and report the ABS code.
Factoryjack
Feb 1, 2010.
