Ignition switch replacement
1999 CADILLAC SEVILLE
15,000 MILES
JKRUG
  • 6 POSTS
I have the radio and heater removed, two screws on the radio side removed, electrical connectors removed, I can release the lock tab for the park/lock cable but can't seem to push it back far enough to remove it from the housing, also not sure how to remove ignition bezel and light ring
Mar 27, 2012 at 5:12 AM
  • CAR REPAIR CONTRIBUTOR
Start by disconnecting the battery here are the instruction on how to replace the ignition switch int he diagrams below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Mar 27, 2012 at 7:44 AM
JKRUG
  • 6 POSTS
The ignition switch is in the dash not the steering colum.
Mar 27, 2012 at 7:58 AM
Which one are you trying to replace? Is it the ignition switch or the ignition cylinder lock?
Mar 27, 2012 at 8:34 AM
JKRUG
  • 6 POSTS
The one in the dash the key goes into.
Mar 27, 2012 at 8:57 AM
See above
Mar 27, 2012 at 10:28 AM
Above is your ignition cylinder lock for 99 Caddy deville
Mar 27, 2012 at 10:30 AM
JKRUG
  • 6 POSTS
I have a '99 Seville SLS, would that be a different procedure than a Deville.
Mar 27, 2012 at 2:21 PM
Its the same
Mar 27, 2012 at 3:00 PM
JKRUG
  • 6 POSTS
I'm trying to attach a photo, the photo you added does not look like my ignition lock cylinder, mine is in the dash, I have to go through the radio, hvac opening to get to it, it's not in the steering colum
Mar 27, 2012 at 4:33 PM
JKRUG
  • 6 POSTS
I don't know how to attach photos, if there's a number I can message them to I'd like for you to see them so you can see I'm not crazy.
Mar 27, 2012 at 5:23 PM
LOGFORNEY
You have to drop the steering column also. There is another bolt that can only be accessed from the steering column side.
As far as the "ignition bezel and light ring", they are part of the lock cylinder, which when you depress the metal tab through the radio opening, you have to get a good grip around the ring and pull the lock cylinder out. You may need to use a screwdriver to break it loose, but be careful not to gouge your dash. Once you drop the steering column you should be able to get better access to get the park lock cable out. The switch is removed through the radio opening. You have to twist it to get it out.
Apr 16, 2012 at 11:27 PM
BOB BEEMAN
How so you change the ignition switch? Thank you.
May 7, 2020 at 11:28 AM (Merged)
REMOVAL PROCEDURE
https://images.2carpros.com/forum/automotive_pictures/12900_i1_1.gif
Apply the parking brake. CAUTION: Refer to Battery Disconnect Caution in Cautions and Notices. Disconnect negative battery cable. This will maintain the key code. CAUTION: Refer to SIR Handling Caution in Cautions and Notices. Disable the SIR system. See: Body and FrameInterior Moulding / TrimAir Bag(s) Arming and DisarmingService and Repair Remove the radio or the navigation display module. Remove the AC/heater control head. Remove the knee bolster. Remove the steering column. Disconnect the electrical connectors from the ignition switch. Disconnect the park lock cable from the ignition switch. Refer to Park Lock Cable Replacement (LHD) in Automatic Transaxle-4T80-E. Remove the ignition switch cylinder. Remove 1 fastener from the access hole in the IP at the steering column opening.
https://images.2carpros.com/forum/automotive_pictures/12900_i2_1.gif
Remove 2 fasteners from the radio opening hole. One fastener (2) is at the top of the opening and the other fastener is near the opening edge. The head of the screw is facing forward. This is a blind fastener. It can not be seen when installed.
https://images.2carpros.com/forum/automotive_pictures/12900_i3_1.gif
Rotate the switch in the IP. Remove the ignition switch through the radio opening. Remove the fasteners (1 2, 3) securing the ignition switch bracket to the switch. Remove the ignition switch bracket from the ignition switch. INSTALLATION PROCEDURE
https://images.2carpros.com/forum/automotive_pictures/12900_i4_1.gif
Install the ignition switch housing bracket to the switch. Install the fasteners (1, 2, 3).
https://images.2carpros.com/forum/automotive_pictures/12900_i5_1.gif
Install the ignition switch into the radio opening. Install the 2 fasteners to the radio opening hole, one fastener (2) is at the top of the opening and the other fastener is near the opening edge.
https://images.2carpros.com/forum/automotive_pictures/12900_i6_1.gif
Install 1 fastener to the access hole in IP at steering column opening. Install the ignition switch cylinder to the ignition switch housing. Install the park lock cable. Refer to Park Lock Cable Replacement (LHD) in Automatic Transaxle-4T80-E. Connect the electrical connectors. Install the steering column. Install the knee bolster. Install the AC/heater control head. Install the radio or the navigation display module. Enable the SIR system. Connect the negative battery cable. Release the parking brake.
BROWNSGUY
how do i change the ignition cylinder?do i have to remove the steering wheel?how do i do that?
May 7, 2020 at 11:29 AM (Merged)
BLACKOP555
  • 10,386 POSTS
to change the ignition put the key in and turn it to the on position from there examine around the ignition you should find a little hole or little button push it wiht a punch and pull out the ignition. Should not require to much force.
BUZZSAW
  • 1,198 POSTS
[quote:d842e3a42d="brownsguy"]how do i change the ignition cylinder?do i have to remove the steering wheel?how do i do that?[/quote:d842e3a42d]
even if you do get it out and changed, you still will have to tow it to the dealer and reprogram the scurity system to match the new key
BLACKOP555
  • 10,386 POSTS
depends on the year of the car.
BUZZSAW
  • 1,198 POSTS
[quote:1ab16c6655="blackop555"]depends on the year of the car.[/quote:1ab16c6655]
no it doesnt on a caddy
BOBPAT1
Electrical problem
1989 Cadillac Seville V8 Two Wheel Drive Automatic
how do I replace an ignition switch cylinder
FACTORYJACK
  • 4,159 POSTS
It requires some steering column disassembly, and if it is a telescopic column, some special tools. The airbag, steering wheel, and turn signal switch need to be removed, along with lower knee bolster and panel. The cylinder comes with wire leads that need to be fed down the column.
