Mechanics
99 NEED SOME HELP WITH THESE CODES I PULLED
1999 Cadillac Seville
Electrical problem
1999 Cadillac Seville V8 Front Wheel Drive Automatic 133000 miles
I need some help, I've been having the Traction control light staying on, and the ABS light coming on and off every so often, it annoyed me to the point of where I decided to reset the codes and took about a 200mile ride over about 3days. And I got the new codes and their description, the ones that showed up as " current" are labeled with current near them, the rest came up as history but they obv arent exactly history if I got them again XD
MSM -
B1860 - Driver Lumbar Vert Sensor Circuit Malfunction
SDM -
B1163 - Loss of Serial Data-No Lamp Response
U1040 - Loss of Class 2 Communications with ABS
U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction)
PCM -
P1520 - Transmission Range Switch Circuit *current*
P1571 - Traction Control Torque Request Circuit *current*
P1602 - Knock Sensor (KS) Module Performance
IRC -
U1144 - Loss of Communications with PHN
IPM -
U1066 - Loss of Communications with RIM
IPC -
U1301 - Class 2 Short to Battery
DIM -
AMP -
U1064 - Loss of Communications with DIM
U1128 - Loss of Communications with IRC
ABS -
C1236 - Low System Supply Voltage
C1277 - Requested Torque Signal Circuit Malfunction *current*
U1056 - Loss of Communications with RSS
U1016 - Loss of Class 2 Communication with VCM
also, alot of times when im going up a steep incline and put my foot on the peddle harder, my music will turn off and at times a " beep" will sound after the music turns off along with the ABS light flashing on for a moment then shutting off, then my music will come back on.
the engine its self sounds amazing in my opinion. Starts up in the first 1-2 seconds of turning the key in the ignition.
Thank you to anyone that can offer help
Crazyfurie
October 2, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
