2006 Cadillac Fleetwood Repair Question
Asked on December 12, 2008
2006 Cadillac Fleetwood water temp
Engine Cooling problem
2006 Cadillac Fleetwood V8 Two Wheel Drive Manual
I am running a ls1 motor in a offroad car and burnned up a piston,I had it repaired my a good machanic.I just replaced 1 piston and had the cylinder ressleved.The normal water temp allways ran at 180 degrees,after the rebuild it now runs at 210 and if I run it hard it climbs to 220.I have tried burping the radiator thinking I have a air lock,but I get nowhere.Is there anything else I can try.I have not changed anything on this car since the rebuild.I still am thinking there is a airlock,Is there any special tecnique on getting the air lock out.
Thanks guys
Johnny
Thanks guys
Johnny
Answer
Replied on January 1, 2009
Johnny,
First the normal operating temp for this car is around 200 degrees. Have you tried a cooler thermostat?
