Will not start no dash lights totally gone and does nothing when key is turned?
2003 CADILLAC ESCALADE
115,000 MILES • V8 • AWD • AUTOMATIC
RUBEN GUTIERREZ
Will not start no dash lights totally gone and does nothing when key is turned to start position.
Dec 2, 2010 at 4:26 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
Hi Ruben,
It sounds like the battery is totally gone. Try turning the headlight on, if they don't come on replace the battery, here is a guide to help you.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
If the battery is good check the connections this guide will help.
Mar 17, 2017 at 1:08 PM
NEY85
My escalade was fine until yesterday. i tried to start it this morning and wont start i can hear the motor crank but wont i try staring fluid but it wont start and its a bit cold outside so i dont know if is the weather and the fuel froze up or what?
Mar 17, 2017 at 1:09 PM (Merged)
DRCRANKNWRENCH
  • 3,380 POSTS
There are a few possibilities;
Here is the link;
NEY85
thank you im gonna try that
DRCRANKNWRENCH
  • 3,380 POSTS
Let me know how it goes.
RGADBAW
I own a 2003 Cadillac Escalade and it would not start for my wife the other night. She finally got a jumpstart to get it home. I put in a new battery but I get nothing what so ever. No lights on the dashboard or anything. Does anyone have any suggestions.
FACTORYJACK
  • 4,159 POSTS
Does the new battery have a charge?
RORRO1
Engine Performance problem
2003 Cadillac Escalade V8 Four Wheel Drive Automatic 84365 miles
MY 2003 CADILLAC STarts sometimes a drove it last time and the next day did not start. i replace the battery and still did not start.few hours later starts some times starts and later i try to start and it did not. when i try to start it does not crank or noting looks like there is no power all all but all my lights come on but engien does not starts.
FACTORYJACK
  • 4,159 POSTS
If all your lights come on, and you have this concern after changing a battery, the you will need to check to see if the starter is getting a signal when it don't start. If you have a test light, check for power on the small wire at the starter when key is in crank. If the light lights, you need a starter.
PIRATENURSE
Engine Mechanical problem
2003 Cadillac Escalade V8 All Wheel Drive Automatic 103,00 miles
Have a 2003 Escalade with 103,000. Tried to start, all lights come on but, engine didn't start. Tried locking/unlocking by using both key fabs with no luck. Tried unhooking the battery + cable for about 5min with no luck. Now the dash lights are not coming on. All that light up is the symbol of a engine. Any ideas before it gets the rollback????
HMAC300
  • 48,601 POSTS
check the condition of the battery first. if it's bad it screws up everything. Then check the large fuses in the underhood electrical center. you should be able to see if they are blown or not. Also check on the starter for a fusible link wire that may have burnt up. That's to protect your system. It may be the large red wire leading to the underhood electrical center....
