4.9 162000 MILES
1991 Cadillac El Dorado
We are having a problem with the brake lights. The center high mount brake light works, but the rear brake lights do not work. I have checked the brake light switch with a multimete and it tests fine. I am strarting to think that there is a break in the wires, but I can't see both sides not working.
April 15, 2007.
Tried the bulb? If you have a multimeter, check for power when the pedal is pressed! No power = check wires! Power = replace bulbs!
Aug 13, 2007.
